What kind of box?
Username: Usmc_gypsy
does anyone know what kind of box i need ported or not for 2 12 inch MTX Thunder 900 Watt(450 watt each). These are the specs
2 New MTX T4512 12 Inch Subwoofers
Power Handling: 900 Watts (Pair)
Power Handling: 450 Watts (Each)
Power Handling: 450 Watts (RMS Pair)
Power Handling (RMS): 225 Watts Each
Impedence: 4?
Voice Coil: 1.5"
Frequency Response 30 - 150 Hz
Sensitivity 92.97 db
Magnet Weight 35.00 oz.
Mounting Depth 5 9/16
Cut Out Diameter: 11 1/16"
Magnet Weight (oz.): 35
Port Dimensions: 4" Diameter X 10" L
Port Displacement: .22ft Cubed
Sealed Enclosure Net Volume: 1.25ft Cubed
Speaker Displacement: .05ft Cubed
Tuning Frequency: 37 Hz
Vented Enclosure Net Volume: 2ft Cubed
When it says vented is that the same as ported? Also can anyone tell me if these are good speakers or not?
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5475
you literally made this exact same thread earlier and i answered you.
Post Number: 5477
https://www.ecoustics.com/electronics/forum/car-audio/475199.html dumbass.
