15" Enclosure vs. Port
Username: Zachxltg
I am purchasing 2 15" Alpine Type-R
And was going to build an enclosure. I am confused though on whether not i should build a port into, what would be the differences from a box with a port vs. without
Username: Rovin
Post Number: 13537
u mean sealed & ported ?
ported louder & box will be bigger
sealed = much tigher accurate bass ....
Username: Peakohm
Post Number: 13
If you want louder and listen to mostly rap, go ported. It will be boomy and not sound as good as the ported. It's possible to port it and tune the box low and get a very good mix of both.
If you look for sound quality and being accurate, go sealed. It won't be as loud though.
Username: Nyyfan13
15 MAG USA
Post Number: 9350
Ported boxes can still sound just as good as a sealed box if built and tuned correctly.
