Box Build pix for ppl that like that kinda thing
Username: Durski
Post Number: 405
something like 3.4 cubes @ between 31 and 32 hz
Rhyno Liner will be done 1/2 way through next week, should be installed by next weekend.
Diamond Member
Los Angeles, CA USA
Post Number: 20311
i don't like that kinda thing but good job. came out really nice.
jp about not liking that kinda stuff.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5793
howd you cut the wood??
you got some skillz
Username: Th3pwn3r
I compensate...
Post Number: 7926
I wonder if Tito Ortiz likes the feeling of throwing a hot dog down a hallway.
Username: Durski
Post Number: 406
lowes did most of the initial cuts, then I fixed their mistakes with a dremel and a jigsaw.
Username: Mgbcs
Lincoln, Nebraska
Post Number: 2402
What's going in there?
Username: Durski
Post Number: 407
15" Fi.Q
A pic is worth 1000 posts!!
Post Number: 16038
Goody goody. FI eye candy.
Username: The_image_dynamic
San Diego, California
Post Number: 3802
Looking good Chris. Buy a can of Herculiner and brush or roll it on. I have used it on hundreds of boxes and it is awesome stuff.
LOL Rob. she went in for "vaginal rejuvenation" lately. Fücking her went from the feeling of tossing your dick out a window to humping a virginal high school cheerleader in one day. I wonder if the doc got to give it a test run.
Username: Durski
Post Number: 408
Thanks for the comments fellas, means a lot since this is my first build that I wouldn't be embarassed to show someone.
I had already dropped off the box at the rhino place before I made the post, and I'm kinda tired of messin with the box, but I'll keep the herculiner in mind for future uses.
Another recent build I'm not too embarassed to show...
Looks crazy with the lights off
Username: Rovin
Post Number: 13572
sweet pic !
OH & Box looks very good to especially for ur 1st .....
Username: Andrew571
Post Number: 1713
looks good. What did u use to cut the wholes i must ask...
The reason is because u made a compass and drew out the circle... But the holes are cut very neatly... Jigsaw skillz?
Username: Durski
Post Number: 409
jigsaw first, then fine tuned em with a dremel and lots of patience
Username: Durski
Post Number: 410
the sub wouldn't set all the way down at first, better too small of a cut than too big right? double baffle made it take extra long to get right
Username: Nyyfan13
15 MAG USA
Post Number: 9321
Looks good Chris.
The sub cut-out hole is probably the same size as her "hole", if you catch my drift.
Username: Redliner
Wilmington, Ma
Post Number: 4285
but yet who here would say no lol
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 5381
i would say no... who knows what that chick has.
sweet box though.
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1980
Yanks is right her whole is too big i'll pass. But i'll let her su(k it.
Oh by the way good job on your first box.
Username: Andrew571
Post Number: 1715
i need to invest in a plunge router....
anyone know any good deals on one?
Username: Big_edge_head
Milwaukee, Wisconsin MY SUBS GET ...
Post Number: 1934
that box looks great man.
Uploadnice banana smilies Brad. lOl
