Best Sound Quality Amp for highs
Username: Beatin_down_yo_block
Okalhoma City, Oklahoma United States
I HAVE 6 PIONEER PREMEIR 6X9'S AND I NEED THE BEST SOUND QUALITY AMP.. A 2 CHANNEL AND A 4 CHANNEL WITH THE SAME RMS.. FOR ALL 6 SPEAKERS.. CANT DECIDE BETWEEN ALPINE, MB QUART, OR CROSSFIRE.. ANY SUGGESTIONS
Username: Stateprop486
PA
Post Number: 1385
umm amps doesnt really produce sound quality, your not going to notice in sound from an amp. but look into some kicker amps.
kicker's thd is 0.05/// would that be better than a crossfire at 0.02??
Username: Drant19
DUB-C, TX
Post Number: 711
wont notice a difference at all
okay so someone make the choice for me ok,, here we go.. now should i go with ALPINE PDX the stackable new ones, CLIFF DESIGNS, US AMPS, or MB QUART PREMIUM. for my setup of 6 6x9s.??
Username: Drant19
DUB-C, TX
Post Number: 714
alpine, us amps, MB quart are all great amps. pick which one is cheapest...
Username: Nd4spd18
Northwest PA
Post Number: 7264
How the hell did cliff designs get in there with those haha. Cliff is crap, all the rest of those are very good brands of amps.
Has to be the Merlin line for US Amps though not the XT.
Post Number: 10
ok so here we go, iTS out of Mb Quart or Alpine,, Because I cant find a Crossfire vr804 and vr404 combo TO SAVE MY LIFE and it pisses me off... Ok so take a look at my choices fellas and help the poor man out..
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17700
and here is its little brother
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17699
Now seriously in terms of real world wattage and durability would the mb quart be better than the new alpine pdx???
and In case you havent seen the alpine here is a look
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18377
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17193
TELL ME WHAT YOU FELLAS THINK ON THIS ONE
Username: Chaunb3400
All he does is catch t..., Alabama U.S.
Post Number: 14134
get the pdx's just cuz imo they look good, and we all no how they perform
but ur not gonna notice any difference
Post Number: 17
and if im going with 6 6x9's in the back what should i put in the front???
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 1996
if you want sound quality you shoulda got some component speakers
Username: N2audio
Lawrence, Ks USA
Post Number: 1527
6 6x9's in the back is ANTI-Sound Quality.
Username: Nd4spd18
Northwest PA
Post Number: 7312
^^^^^ hahaha true that
Post Number: 23
im talkin bout in the back window,, and how is that anti-sound quality... and i am going to get some components
Username: N2audio
Lawrence, Ks USA
Post Number: 1531
if you truly want "sound quality" -- as in the way things sound in the studio when they're recorded. You want the vast majority of the sound coming from the front of the car. Compared to a GOOD component set nicely installed up front getting plenty of power 3 prs of 6x9's in the rear deck is just noise.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5277
you should read the article of Rearfill or not. That way you'll learn some good stuffs
