Products Needed To Have A Good Audio System
Username: Tylermoncrief
Just list the requirements to have a good system
Like what will you need
exclude screw drivers and other tools
Because, I want to start up a fresh system
in my friends car
lazymf
...I could tell you what it is, but you should do the search to get some answers what this board is all about
Username: Jonathan_f
GA USA
Post Number: 170
Do you mean tools, or what type of speakers?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 3291
depends on how you define good.
having pneumatic and electric tools like an air-nibbler, hydraulic lift, air-saw, impact wrench, and so on are a huge help for doing serious work, as are power tools like a circular saw, arbor/table saw, band saw, scroll saw, jigsaw, drill press, router, and so forth.
There are a number of specialized tools as well for things like body work, removing particular items like door handles, window cranks, and body panels with plastic cotters, some factory units need special removal tools as well (Datsuns, Fords, etc)
If you want to get into fiberlgass work you'll need more tools beyond the above.
What I mean by products is like
What would be the best sysyem period
What would be the cheapest system but has
good quality
What amp to go with a certain brand
GA USA
Post Number: 180
There really isn't a "best" system. If there was, everyone would have it as a goal and you'd have heard about it by now. As far as cheap goes, JBL makes some of the cheapest good amps. How much are you looking to spend on component speakers and subs?
Im looking to spend $400 or less for good quality
Username: Its_bacon12
Post Number: 610
a..hmm....
cant get much good quality stuff for $400
adire audio shiva $125
rockford 501s $185
some headunit? $100?
well thats best i can say for quality for your money
Username: Pat_l
Tucson, AZ USA
Post Number: 175
Save up more money! Building a box is harder and more time consuming than you think. If you have minimul knowlege about tools (not tin snips and screwdrivers) than dont build a box. You have to know and do alot of prep work before you build.
Post Number: 7
I got a JVC head unit already
I got a 12" bandpass enclosure already
Username: Pat_l
Tucson, AZ USA
Post Number: 179
Good now get some subs and AMP!
Post Number: 12
I kno that....What are some good subs and amps that are under $400
if your box is dual get 2 kicker comp vr 12's and a jbl 600.1 that is well within your range
