FS: RD Audio Alpha 15 with fresh recone
Username: 04redmach1
Lagrange, GA USA
Post Number: 1695
Well, I got a dual spyer Alpha 15 now and going to recone the single I got into a dual as well but going to sell it since I have already started pounding this one. $325 OBO shipped and it's yours.
Kevin
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 909
is that a dual 2Ohm?
Lagrange, GA USA
Post Number: 1696
Sure is.
Kevin
Lagrange, GA USA
Post Number: 1697
I havn't reconed it yet, so if you want single spyder I can do that as well, but will be dual for now.
Kevin
Post Number: 913
i'm sendin u an email
Username: Teamrevolution
ATLANTA, GA USA
Post Number: 244
Recone it with a flat wind if you want 2500 RMS and 94.2 DB @ 1watt.
Username: Zacdavis
Beloit, Wi
Post Number: 1630
yeah but at what frequency?
ATLANTA, GA USA
Post Number: 251
Fs will drop down to upper 20's after break in If you tune 32-34ish and set your subsonic at your f3 you should be ready to roll.
Personally i like them in a 4 cube box tuned to 36-37hz with an f3 around 32-33hz.
With alphas we make them to your wants, Got guys who only want 1 spider for sound quality and 1000-1500w, got guys who want 2 spiders for 1500-2000w or dual spider with flat winds for ground pounders. The design was never for pure SPL it just happened that 50hz+ with 5+k on the reg dual spiders produce excellent numbers.
We will have a few guys running dual spider alphas at heat wave Austin and a couple with flat winds.
So in a couple months i can get some honest drop in tests with flat winds vs round and at same and diffrent power.
Guess it just depends on your likes.
Another thing is 2500w rms on the flat winds is with clean power.
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 4921
Steve, you should stick around the forums more often! I got a quesiton about the new Elite though. Have you tested the output on it at all?
Username: Jtown
Team RD, Texas
Post Number: 2636
hey Steve, are you getting discounted tickets to get into heatwave? that sh1t is expensive and I would really like to help out since RD will be in the area. I've got my 12" alpha tuned to ~31hz right now.
Username: Jtown
Team RD, Texas
Post Number: 2637
best bet is to call him Reece, I think his shop number is posted on the rdaudio.net site
Post Number: 4922
elites in 15" ftw. i'm going to start a petition so i can buy a couple..
Http://www.rdaudio.net...
Post Number: 19714
good idea. i would definately pick on up.
