Test tone CD
Username: Deadrabit
Post Number: 251
i need a CD that has something like 1 to 100 Hz were i can write down what i hit db wise with each one.
i am going to see what my car is tuned to for making my next spl box. i have a mic that i can use i just need a cd! i can't find anything on limewire!!!
any one have one? or know were i can get one at?
Username: Hittin1
LakeCharles LA., La
Post Number: 39
i use ares p2p and got all my hz tones fron there... u can try using BASS MEKANIK on your audio search.. I had bad luck with limewire... get too much bullsh!t on it when searching... http://realmofexcursion.com/ then go to download section is another option.. if this doesn't help email me and I will try to do more... maybe file transfer of some sort. L8r
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2294
i was watching the vids from the meet and ms had a cd and people were using track 18. ms if you read this what cd/song is it?
Username: Nd4spd18
Northwest PA
Post Number: 6864
Haha that was my CD, I made it. Thats the disc I use all the time for testing and comps, it has sine sweeps (what we were using) and all different test tones.
I used test tone generator 4
http://www.download.com/Test-Tone-Generator/3000-2169_4-10070156.html
I bought the license for that software a while ago.
Username: Snarl2004
Post Number: 2296
any chance you want to email me the sweep
Username: Hittin1
LakeCharles LA., La
Post Number: 42
i have a 10hz-200hz. sweep if u want it.... need your email
Username: Deadrabit
Post Number: 252
my email is worrblade@yahoo.com!
HOOK ME UP MAN!
Username: Insearchofbass
Post Number: 8489
what mic are you going to meter it with
Username: Hittin1
LakeCharles LA., La
Post Number: 43
i emailed it to ya... let me know on here if it worked.... l8r
Username: Nd4spd18
Northwest PA
Post Number: 6868
I could send it to you I don't have it on this PC though I'll have to get it from the disc.
DON'T use any mp3 files........ test tones / sweeps need to be .wav files. You will get a slightly lower score on the meter if you use anything compressed.
Username: Snarl2004
Post Number: 2297
my email is singingviper "at" yahoo.com
if you could send it to me i would greatly appriciate it
Username: Blainew
Post Number: 2867
you better be careful with downloaded test tones
Username: Skibum12189
Cleveland
Post Number: 2729
^^^yup
you can order the JL calibration cd for like less than 10 bucks
Username: Somedonniedude
Illinois United States
Post Number: 1215
Blaine what do you mean?
Username: Frkkevin
Post Number: 4787
check ROE .. http://www.realmofexcursion.com
Username: Hittin1
LakeCharles LA., La
Post Number: 50
ROE under download section
Username: Deadrabit
Post Number: 253
what is wrong with downloading them???
i got that one thing and made my own and that one dude sent me one! thanks! yay!
