Batcap2000 vs kinetik 2400
Username: Basebalz13
Moneta, Va Usa
Post Number: 356
wat is the major difference like is the batcap 2000 amps and the kinetik 2400? and so if so what other differnce like if they was both the same amount of amps which would be better?
Username: Nd4spd18
Northwest PA
Post Number: 6836
Batcap is a battery with a high esr (basically useless) capacitor on it. Kenitik all the way.
Moneta, Va Usa
Post Number: 359
well wat about kinetik or powermaster?
Username: Philly306
New quote coming soon, North carolina
Post Number: 969
theres a comparison on low hz about these two.
i believe they gained a few db with the batcap. not multiple db but like .4 difference.
I don't know alot about batteries though.
Username: Nd4spd18
Northwest PA
Post Number: 6840
Between all these batteries of the same size just different brands, you will notice absolutely no difference unless you're competing.
Moneta, Va Usa
Post Number: 360
Well im trying to compete so yea it does matter
