Amp and EQ
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 2335
I need a good amp for my alpine type r components (<100w rms) and a really nice EQ that puts out at least 4volts. Im looking to spend no more than 300 for everything. If I have to spend more, I will. Thanks for the input guys
Username: Stateprop486
PA
Post Number: 904
do you have the Apline SPR-17S comps Andrew? because those are the ones i got but i didnt install them yet. i was going to get the ZX250.2 to run them. 85watts x2 @ 2ohms. cheaper ones on then that on ebay but im just showing u. r u could go with the zx350.2, that does 110watts x2 @ 2ohms.
http://cgi.ebay.com/KICKER-ZX250-2-CAR-AUDIO-250W-2CH-AMP-AMPLIFIER-XOVER_W0QQit emZ310022890353QQcmdZViewItem?hash=item310022890353&_trksid=p3285.c58.l1288
Username: Joebruce
15 AQ HD3
Post Number: 1759
"i was going to get the ZX250.2 to run them. 85watts x2 @ 2ohms"
How are you going to run your comps at 2ohms?
PA
Post Number: 919
lmao. i meant 4ohms
Username: Joebruce
15 AQ HD3
Post Number: 1761
Ahh ok,jus checkin.
