Amp choice?
Username: Bonhamd
Northern, Michigan USA
Post Number: 473
massive audio p3000.1 or kicker zx2500.1?
i dont know much about either...they are pretty close in price right?
what would be the better choice?
Username: Stateprop486
PA
Post Number: 936
aq 2200D $389 shippd
Username: Bonhamd
Post Number: 474
i want something with more power and into 2 ohms - thanks for the suggestion though
Username: Joebruce
15 AQ HD3
Post Number: 1784
What subs do you have and what vc are they?
Username: Bonhamd
Post Number: 476
treo ssx dual 1
Username: 420alldaylong
Post Number: 3321
ZX2500.1 hands down but im not sure on the prices.
Username: Nd4spd18
Northwest PA
Post Number: 6630
Kicker, thats no contest
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 829
Username: Bonhamd
Post Number: 477
any suggestions on amps that will do 2500-3000 into 2 ohms?
is tthe 2500.1 the best choice?
Username: Talon01
Team Revolution , Pa Usa
Post Number: 968
i would say the kicker out of those 2
PA
Post Number: 960
kicker FTW then.
Username: Bonhamd
Post Number: 478
any other suggestions for an amp that will do that kind of power into 2 ohms?
Username: Bonhamd
Post Number: 483
to the top - any other suggestions on an amp that will do 2500-3000 into 2 ohms?
Username: Spivey17323
Dunellen, New jersey 15 inch Alph...
Post Number: 1429
correct me if im wrong but im pretty sure that the massive does its power at 1 ohm so why were you interested in that.
Username: Bonhamd
Post Number: 485
i think its 2 ohms unless holdens site is wrong
http://www.low-hz.com/commerce/catalog/product_info.php?cPath=21_28&products_id= 56
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2218
i would get the kicker out of those two. it probly puts out a little more power to and its better build quality. ive got the P3000.1 and it works fine but if i had the choice between the 2 i would get the kicker
Username: Bonhamd
Post Number: 486
2 ohms right?
PA
Post Number: 994
u could also do the KX2500.1 its a 05 model its cheaper then the ZX2500.1.
http://cgi.ebay.com/ebaymotors/Kicker-05KX2500-1-mono-Amp-2500-1-BEST-PRICE-ON-E BAY_W0QQcmdZViewItemQQcategoryZ38638QQihZ004QQitemZ140212692094QQrdZ1QQsspagenam eZWDVW
Username: Bonhamd
Post Number: 487
im still going to wait and check price differences...
i think troy is getting some 2500.1s soon though.
Post Number: 3324
2 USAmps MD-2D for under $630 and strappable to 2ohm load.(3000+RMS)
