Bass Box 6 Pro
Username: Evoixmr
Post Number: 202
Anyone know a serial code that works?
Username: Stateprop486
PA
Post Number: 792
did u search on frostwire for the keygen?
Username: •cam•
BC Canada
Post Number: 2064
I might have one...
Ah, so I do.
6049808b04535pl
Username: Evoixmr
Post Number: 203
"6049808b04535pl"
I tried that one and it didn't work. Do you have it installed?
Username: Hdubb
Team Revolution
Post Number: 3321
6120102b063406
Username: •cam•
BC Canada
Post Number: 2065
Yup. Works grrrrreaat. Hmm. Do you want my version so you can use that? It's 28.2 MB. RapidShare?
Username: •cam•
BC Canada
Post Number: 2066
Let me know if Hunter's works.
Username: Yukhui
4 15 AA Havocs, Memphis 4kw!!
Post Number: 893
theres one somewhere on downloads for teamssa forums i think
Username: Evoixmr
Post Number: 204
cam
That would be coo if I could get it off you.
Username: •cam•
BC Canada
Post Number: 2069
K. Will get uppin'. Link in about an hour. Got some homework to do.
Username: Evoixmr
Post Number: 205
I'll be around, thanks man
Username: Jtown
Team RD, Texas
Post Number: 2365
are you linking the whole program?
if so, I might need to download that:-)
Username: •cam•
BC Canada
Post Number: 2071
No problem.
They scan the net for links to illegal shite so change ".kom" to ".com".
http://rapidshare.kom/files/95529691/BassBox_Pro_v6.0.18.zip.html
Username: Jtown
Team RD, Texas
Post Number: 2370
so is it the whole program?
Username: •cam•
BC Canada
Post Number: 2074
Yup. Everything. A bunch of updates included. I use it all the time and there are no problems with the key. Just make sure you install the updates. Not sure but the serial might not work without them. There is a text file in there that will tell you the order to install them in. I believe it's labeled "Install updates in the following order.txt".
Username: Evoixmr
Post Number: 207
anyone else tried to install yet?
I cant install cuz neither serial is working, and cant run updates unless program is fully installed. What should I do.
Username: Jtown
Team RD, Texas
Post Number: 2371
the link is'nt even working fo rme,......sorry I"m drunk, but it's still not working for some reaosn....
Username: Evoixmr
Post Number: 208
It works, got it running this morning.
windows vista sucks.
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1207
lol thieves did you change the .kom to .com
Boca Raton, Florida
Post Number: 1208
thanks works great.. i just wish it had some of the new drivers installed Fi and Audiopulse.. but o well
Username: •cam•
BC Canada
Post Number: 2075
You can just get the specs and type them in.
Username: Jtown
Team RD, Texas
Post Number: 2373
no.....
Username: Jtown
Team RD, Texas
Post Number: 2374
wait...what do I click to download once I get to the site? premium or free?
Username: Evoixmr
Post Number: 209
free
Username: Jtown
Team RD, Texas
Post Number: 2376
can someone give me a walkthrough on how to open everything and set it all up since I'm a noob at such things?
Username: Van_man
Boston South, MA
Post Number: 3532
dl the program. save it to a folder. unzip all the files. run set up, enter code, enjoy.
Boca Raton, Florida
Post Number: 1220
Yea i know you can enter them in.. but not all the info is there on some subwoofers
