Bronze Member Username: Justin_13Post Number: 17 Registered: Feb-08 | will a powerbass asa 1000.1d amp work with two kicker cvr 12" 4 ohm subs? |
Gold Member Username: 420alldaylongPost Number: 3293 Registered: Sep-06 | I seen this setup a couple of times and it sounds good if the subs are in the rite boxes. Wire the subs to 1ohm like this. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42 |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1482 Registered: Mar-04 | should work real well |
Bronze Member Username: Justin_13Post Number: 20 Registered: Feb-08 | even if its only a one channel amp though? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6360 Registered: Jul-06 | All subwoofer amps are 1 channel (mono) |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 6955 Registered: Jul-06 | 2-Channel XXV Maxximus 2 x 2000-Watts....RMS @ 4-Ohms 2 x 3500-Watts....RMS @ 2-Ohms 2 x 5000-Watts....RMS @ 1-Ohm 1 x 7000-Watts....Bridged Mono @ 4-Ohms 1 x 10,000-Watts..Bridged Mono @ 2-Ohms |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6367 Registered: Jul-06 | As soon as I posted that I knew someone was going to be a smartass........ figures it would be Rob MOST sub amps are one channel. Nuber of channels has nothing to do with number of subs you have. |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 6964 Registered: Jul-06 | ^_^ hahaha. I've seen quite a few 2 channel monoblocks. |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1483 Registered: Mar-04 | FWIW - the maxx is just 2 goliath's in the same chassis - every dual channel mono I know of uses a similar configuration. |
Bronze Member Username: Justin_13Post Number: 23 Registered: Feb-08 | so that amp could power both of them? and could i wire them? |
Gold Member Username: 420alldaylongPost Number: 3297 Registered: Sep-06 | Yes wire it to 1ohm just like in the link above I gave you. |
Bronze Member Username: Justin_13Post Number: 25 Registered: Feb-08 | but will the amp hav enough places to wire both of the subs? |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6372 Registered: Jul-06 | LOL it doesn't matter if the amp only has one set of terminals you just put 2 wires in each terminal |
Bronze Member Username: Justin_13Post Number: 26 Registered: Feb-08 | then im going to get that amp |
Gold Member Username: 420alldaylongPost Number: 3298 Registered: Sep-06 | Where are you buying the amp from? How much for the amp? |
Bronze Member Username: Justin_13Post Number: 27 Registered: Feb-08 | im going to order it off the internet |
