Jl
Username: Pbplayer05
Carroll, Iowa
Post Number: 515
well i can get jl 12w7s pretty cheap would 2 be good on an md2d
Username: Nd4spd18
Northwest PA
Post Number: 6304
JL and cheap do not belong in the same sentence bud
Carroll, Iowa
Post Number: 516
ya i know lol but i can get them for 400 from a friend so is that pretty good would they be worth it an get loud on my md2d
Carroll, Iowa
Post Number: 517
Username: Nd4spd18
Northwest PA
Post Number: 6309
I guess thats a decent price as far as JL goes.
Your MD-2D would be ok for those....... 12W7s are single 3 ohm, so with 2 you'll have 1.5 ohm total. That amp will prob do ~1200w at 1.5 ohm. They could take a little more power but that will do fine.
Carroll, Iowa
Post Number: 518
well for another like 50 he has 13w7 would that be better
Username: Nd4spd18
Northwest PA
Post Number: 6315
Thats would work also..... those are dual 1.5 so with 2 of them they would also wire to 1.5 ohm total........ those can take even more power.
Carroll, Iowa
Post Number: 521
hmm which i could get more outa it i might beable to get his amps he was going to also sell 2 jl 1000/1 for 200 each so for another 400
Username: Nd4spd18
Northwest PA
Post Number: 6318
The two 13W7s and two 1000/1 would kick azz
Carroll, Iowa
Post Number: 522
the only things about that is i would need to upgrad electrical so might just keep my md2d for now and then get my alt and get his amps after that
Carroll, Iowa
Post Number: 524
anyone else got any oppinions on it
Los Angeles, CA
Post Number: 18422
you can get both for $400 or 400 each?
also M.S. just about answered your thread.
Carroll, Iowa
Post Number: 525
both for 400
Los Angeles, CA
Post Number: 18424
that is insane deal. whether you are gonna use it or not, buy it first. NOW!!!!
Username: Van_man
Boston South, MA
Post Number: 3444
get the 2- 13W7's. Get the 2-1000/1's Run the subs off the md2d for now till you get the alt upgrade, then slam those 1000/1 all up in there.
And make a ported box and amp rack for em while your waitng on the alt.
Carroll, Iowa
Post Number: 527
ya i was thinking about using it or selling it they go pretty high on ebay then i could just get something else idk yet but i prolly will pick them up as soon as i get the money for them
