New member Username: Coolguy101Minot, ND Chinka Post Number: 1 Registered: Feb-08 | Alright I got one 12 inch 1600 watt sub and two 2600 watt subs and I was just wondering first off, should I get a power cap, and if so how many farads you think. Then second off, how many watt amp do you think I should get.. I was looking at a 6000 watt amp its just a little frickin spendy. Oh and then I was looking at crossovers and decided that I didnt really need one because I dont have tweeters or middles so yeah. Any help? |
Gold Member Username: Volfenhagking1600SSD Wangin, Shawano, Wis... USA Post Number: 1209 Registered: Oct-06 | what kind of subs do you have (make and model) |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 674 Registered: Feb-07 | if ur running 6k rms ur going to need a HO alt not no cap!!!! |
New member Username: Coolguy101Minot, ND Chinka Post Number: 4 Registered: Feb-08 | I don't have them right now there in my car but I know they are Lanzar. I haven't dared hooking it up yet but yeah. |
New member Username: Coolguy101Minot, ND Chinka Post Number: 5 Registered: Feb-08 | So you dont think if I got a 10 or even 50 farad power cap I could run it? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 675 Registered: Feb-07 | tell me all what you are running the amp maker and modle same gose for the sub's! |
New member Username: Coolguy101Minot, ND Chinka Post Number: 6 Registered: Feb-08 | 2 Lanzar 15 inch Subs MODEL# OPTI1535D I Lanzar 12 inch Sub MODEL# MAXP124D The amp I dont have one yet but I was hoping for suggestions on that. |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 676 Registered: Feb-07 | ok are u going to put in all 3 sub? cuz its not good to mix size!! post a link to Lanzar Audio so i can look at the rms and i can tell u what amp u need and are they svc or dvc and what ohm are they? |
New member Username: Coolguy101Minot, ND Chinka Post Number: 7 Registered: Feb-08 | http://www.lanzar.com/itempage.asp?MODEL=MAXP124D 12 http://www.lanzar.com/itempage.asp?MODEL=OPTI1535D 15's |
New member Username: Coolguy101Minot, ND Chinka Post Number: 9 Registered: Feb-08 | and idk ill do whatever works I dont really care i guess |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 677 Registered: Feb-07 | ok from looking at that you will need a amp that putting out at lest 3k rms i would just run the 15" this is what u will need! u need a 300 amp alt 2 ext batt 1 new one under the hood i get links up soon and you need a amp puttin out 3,000rms @ 1ohm you got two dvc 4ohm sub's just do the two 15" just to make it easy for you! the amp i would use is a sundown saz-3000D you can get it at low-hz.com Kevin Holden is the owner really good guy! and for the batt i would get Step 1. Replace your existing starting battery with a Kinetik HC1400 Power Cell or larger for best fit in your exisiting battery holder. Step 2. Install the following Kinetik HC Power Cells near your amplifier installation: MODEL QTY HC1800 2 http://www.kinetikaudio.com/calc.asp first thing you need to get is a 300 amp alt!!!!!!!!!!!!!!!! i would get one from http://www.excessiveamperage.com/ Nate is the owner best alt for the money!! here is the link to sundown www.sundownaudio.com now have you got the sub's yet? |
New member Username: Coolguy101Minot, ND Chinka Post Number: 10 Registered: Feb-08 | Yeah I got the subs already so i guess ill just sell the 12" so I can get closer to affording the rest and alright I will look into all that thanks for the help! |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 678 Registered: Feb-07 | and i would do two runs of 1/0 awg power wier the lowist costin i found is http://www.knukonceptz.com/productMaster.cfm?category=KLM%20Kable http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qt y=2&woofer_imp=4 and this is how you need to wier ur sub's the top one!!! you got 2 4ohm dvc they go down 1ohm wierd like that |
Bronze Member Username: Coolguy101Minot, ND Chinka Post Number: 11 Registered: Feb-08 | oh alright and I got one more question, do you think this will be pretty nice or what? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 679 Registered: Feb-07 | well it sounds good so far what car are u puttin them in and what kinda box? i going to google some vid's to see what they can do!![]() |
Bronze Member Username: Coolguy101Minot, ND Chinka Post Number: 12 Registered: Feb-08 | Right now ive got a 89 honda prelude si but in a bout a month im getting a 2006 Mustang gt so i should be pretty happy |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 680 Registered: Feb-07 | ok from lookin at this vid they need more power then what he is puttin on them http://www.youtube.com/watch?v=CgCbOsxrpno he say he is puttin 2,400 rms on it! so that 3k amp will do u good now the box i thinking ur going ported? if so i look at what size of box u need and what it needs to be tune to? |
Bronze Member Username: Coolguy101Minot, ND Chinka Post Number: 13 Registered: Feb-08 | yeah thats what i was thinking, could you? |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 681 Registered: Feb-07 | i can't find what size u need? are u doing this setup for spl or sql? |
Bronze Member Username: Coolguy101Minot, ND Chinka Post Number: 14 Registered: Feb-08 | hmm Sql |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 682 Registered: Feb-07 | umm i got work today so i can't call them so u need to call and ask them what size for ur sub's and what to tune it to for daily driving i'm thinking maybe 32Hz is usele what ppl tune there box to i just hope u can fit two 15" in ur car! |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 683 Registered: Feb-07 | sql is more spl with sq wich means hard hitting that sounds good![]() |
Bronze Member Username: Coolguy101Minot, ND Chinka Post Number: 16 Registered: Feb-08 | haha yeah |
Bronze Member Username: Coolguy101Minot, ND Chinka Post Number: 17 Registered: Feb-08 | Well man thanks for all the help. And I gotta head out too, but ill call them sometime Alrighty then thanks tonz |
Silver Member Username: Kingandsons07Lincoln, Nebraska U.S.A Post Number: 685 Registered: Feb-07 | np![]() |
