RE XXX 18" Subwoofer- what amp?
Username: Big_oso
Baldwin Park, CA USA
I just got this sub. It's an 18" RE Audio XXX and I have no idea what kind of amp I will need.
Username: Nickyp0219
Post Number: 449
well the reaudio site says its thermal power handling is 2000rms, so your prob gonna need an amp that does at least that much power, to a 1 ohm load, since its a dual 2ohm sub.
Username: Loc_out
Santa Ana, Ca Resonant Eng...
Post Number: 1664
Is it a new or old XXX?
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7695
javier...
agarrate los huevos puto..
Los Angeles, CA
Post Number: 17675
we need more info javier.
Username: Loc_out
Post Number: 1665
"agarrate los huevos puto"
Ha ha ha no responde porque no los encuentra.
Los Angeles, CA
Post Number: 17676
son mamadas zpeedy.
Username: Loc_out
Post Number: 1667
Zpeedy, Javier Lopez no habla espanol no seas pendejo.
Los Angeles, CA
Post Number: 17677
no seas mamone zpeedy
Username: Big_oso
It is the old XXX. 2005 I believe.
Username: Big_oso
y se me olvido decirle a pinche zpeedy que mame la verga....
Username: Philly306
I have more bass in my..., North carolina
Post Number: 822
como se dice "PWNED" en espanol
Los Angeles, CA
Post Number: 17689
javier i assume the sub is dual 2ohm? if so get the sundown saz1500. that amp should push that nicely.
www.low-hz.com
Username: Big_oso
Ok according to the guy I got the sub from, it is a 2005 RE Audio XXX 18" with Dual 1 Ohm voice coils. I have an MA Audio HK2000D amp (brand new in box) but I dont know if it will be enough. According to the specs in the manual, it does 1800W RMS at 1 Ohm at 14.4.
I hope this info helps.
P.S.: checked out the Sundown Saz1500
Username: Big_oso
Does my sub have a good reputation? I know it's not a name brand like JL or whatever, but it looks like a beast.
Username: Frkkevin
Post Number: 4446
Here in AMERICA english is the primary language :-)
Los Angeles, CA
Post Number: 17696
i'd take the xxx over jl anyday.
since your sub is a dual 1ohm you need an amp that does around 1500-2000wrms at 2ohms. i say go with a kicker zx1500.
Username: Ska
Post Number: 241
"Does my sub have a good reputation? I know it's not a name brand like JL or whatever, but it looks like a beast."
LOL
RE IS a brand name.... LOL!!! You're just not paying a dollar a watt like with JL ;-)
Username: Denali_on_22s
The kids like my rhyme...
Post Number: 3822
go with at least 2000 watts
Username: Ska
Post Number: 243
if its duel 1 ohm, you can wire it UP to 2 ohms, so get a kicker zx2500, or do you guys think that might be too much power for it?
Los Angeles, CA
Post Number: 17701
its the older xxx. it is very efficient with around 1500wrms. yes it can take more but why over do it. not only will it cost more to run that much power but he really needs to get the ho alt. even at 1500wrms he should get a ho alt but he can get by if he takes it easy.
Post Number: 3824
^ this coming from the guy who ran 4000+ watts to a sub rated at 2500... oh chad... you kill me
Los Angeles, CA
Post Number: 17702
hahaha reece. lol. you know me. i am very conservative now. lol.
Username: Big_oso
Ok so let me get this straight. You are recommending the Kicker ZX1500? I checked it out and it seems weak. Lets assume money is no object, what would be the best amp for my sub? Also, where can I get a great high output alternator?
Username: Drant19
DUB-C, TX
Post Number: 330
why assume money is no object? we can throw out many amps that will be ridiculously priced. but all VERY high quality. why dont u post a REAL budget so we can get down to business and find u an amp.
the kicker 1500 will produce around 1900rms. which is perfect for the XXX
Username: Big_oso
Post Number: 7
Ok when you put it like that, you make a great point. If you think the Kicker is perfect for the sub, then I will pick up the Kicker. Any recommendations for electrical upgrades to my car? It's a 2002 Dodge Ram and I have budgeted $1000 for the electrical.
Username: Loudon
Post Number: 2235
ive seen 150 zx1500s and none of them produce 1900 watts ...
in a perfect enviorment at 14.4 ud could see 1700..
ideally ull be around 1550-1650 ...
if ur looking into amplifiers ... why not purchase an amp thats going to be able to be used later on... lord knows people change their audio like they change their underwear ... something 2k -2500 is where u should look ... thermal is 2k put people have ran over 3k on the 05 xxx ...
Los Angeles, CA
Post Number: 17714
mike its the older xxx. the recomended rms for that sub was 1600wrms.
Username: Loudon
Post Number: 2236
oh alright ..
ideally ud be looking at 2k max for daily ...
look into a kicker zx2500 ... i know that sub can take 2500 daily all day long
Los Angeles, CA
Post Number: 17716
just make sure you get a ho alt.
Username: Big_oso
Post Number: 8
The zx2500 is goin for about $700 on Ebay, is that about right? Is there another amp in that same price range or possibly a few hundred dollars higher that would be better suited to my sub?
As for the HO alt, any recommendations?
Username: Th3pwn3r
Post Number:...
Post Number: 6719
You can find the ZX2500 for way less than $700.
Username: Talon01
Team revolution , Pa Usa
Post Number: 811
rdaudio 3250.1d 1600w 2ohm 3500w 1ohm and strapable for more power later on, talk to kevin at low-hz.com for pricing
