Q vs SSD...
Username: Volfenhagking1600
SSD Wangin, Shawano, Wis... USA
Post Number: 1162
Im lookin at upgrading from and SSD(w/flatwind coil) to a Q. Same power...(zx750.1). Would the Q be louder and still retain better SQ with no options?
Username: Nickyp0219
Post Number: 440
how much do you plan on selling the ssd for?
Post Number: 1164
not sure yet...you interested?
Post Number: 444
possibly, i just got an sx so i dont know if id be able to do it right away but anything is possible lol
Post Number: 1165
yea it is... lol how much did you get an sx for? and is it a 15?
Post Number: 1167
bump...instead of a Q. what about a HDC3?
Username: Nyyfan13
15 MAG USA
Post Number: 8179
The Q and SSD will play lower while the HDC3 will be louder. The Q will most likely hold the best sq out of those 3.
Username: Tejcurrent
Post Number: 1046
Depending on the options on both subs and the enclosure you may or may not hear much of a difference.
Username: Insearchofbass
Post Number: 7740
if this is a 15 hdc3 then the lows should be Ok with a 37 hz fs honestly I dont like the sq that much on the low end with the hdc3 12 its acceptable but to be fair it has a 42 hz fs I think ....personaly id do a sd 2.5 over the hdc it sounds better on the lows...set the 2.5 to 600 rms in a daily box and it will slam and give your amp breathing room
Username: Stnorris
RE SX 15, IA US
Post Number: 2238
i talked with scott awhile ago about the ssd vs. the q. he said that watt for watt, the ssd will be about equal or possibly a little louder than the q. on the other side, obviously, the q is gunna beat the ssd in sq.
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5315
look who it is!^^^^^
whats up there steven
Username: Naledge503
Http://www.LowDownForu...
Post Number: 2934
My Q's get loud enough for me.
The HDC3 will get low. I had a pair of sd2.5's tuned to 32 hz and they got low and louder to the ear than my cvx's at the same tuning.
Here is a thread on CA with a guy who has 2 15" HDC3's tuned in the mid 20's....25hz I believe.
http://www.caraudio.com/forum/showthread.php?t=288854&highlight=hdc3
Post Number: 5316
thats a pretty sick score for being at such a low freq.
