1/2 ohm or 1 ohm
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 131
i am think about getting the mmats D3500 amp with quentin and need to with one to go with
Username: Jakeyplaysbass
ASU
Post Number: 2372
depends on your subs...
Username: Kingtutus
Post Number: 132
they are DD3518's
ASU
Post Number: 2373
What voice coil?
Username: Kingtutus
Post Number: 134
whatever i wount
Username: •cam•
BC Canada
Post Number: 1793
Whenever you have the choice, take the higher impedance.
Username: Trunkslayer
Fl US
Post Number: 43
By higher impedance you mean the 4ohm over the 2 ohm. ANd if so Why?
Username: Marcooo
Post Number: 283
I think Cam meant 2 ohm over 1 ohm, then again he said 3518's so maybe he did mean 4ohm, if 's means two, so he could run them off a 1 ohm load, seeing as .5 ohm takes a hell of a charging system, relative to the power, and can be really hard on the amp if you don't know what your doing or the amp doesn't do well at .5 ohm.
RD 1000.1D with SI MAG...
Post Number: 17513
get the 1ohm mmats amp and get the sub accordingly. who knows. you might want to change your amp in the future. finding another 1ohm stable amp is alot easier than finding another amp that is .5ohm stable. always think about the future. lol
Username: Kingtutus
Post Number: 135
ok thank
Username: Zacdavis
Beloit, Wi
Post Number: 1544
I would do it a little different.
Go for the 1/2 ohm amp.
And get dual 1ohm subs.
For street beating, run them series/parallel. The amp will supply PLENTY of power at 1 ohm.
Then, for burping at competitions, you can wire them all parallel to 1/4 ohm load. ;)
