POLO or anyone with knowledge of 16v systems
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 5186
You had a 16v system.
i was wondering how you were able to charge it. did you have a voltage regulator for your alternator? also did you use a step down resistor???
in other words what is necessary to run a 16v system.
Post Number: 5188
bump for some help.
Username: Big_edge_head
Milwaukee, Wisconsin MY SUB...
Post Number: 1233
u bump for some help
RD 1000.1D with SI MAG...
Post Number: 17353
first you could get a 16v batt with a 12v out as well, run this to your fuse box. most starters will take 16v. next you need a big alt(200A, there really is no reason for a 300A running at 16v, you may have a harder time with the external regulator under an everyday condition). then set up your regulator to like 17.4-17.6v. 2 8v or some 16v batts in the back.
Post Number: 17354
also look in to this.
kinetik 16v has 12v hook up for your car and 16v for your audio system.
http://www.kinetikaudio.com/hc16v.asp
Post Number: 5189
lol you got that post from termpro.com chad....
i was thinking of doing that with the kinetik but you still need to charge the 16v system with something.
Post Number: 17356
lol yeah. that is how you learn man.
Post Number: 5190
i know...thats where i go to find all my answers but i thought id ask polo since he had a 16v system.
Post Number: 17359
are you wanting to do this daily?
Post Number: 5191
yup. and of course im going to compete.
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7593
you need a external voltage regulator.. to make your alternator push the the voltage at 16v...
then u need 16 volt batteries for the back... but your main batterie has to be a 12 volt batterie and you have to buy a step down 14 volt regulator box from powermaster i beilve... so the 16volt signal it will change it back to 13-14 volts and feed your electrical system this is just for starting and the back.. but run a line from your alternator directly to the 16 volt battery bank...
and ull be set..
Post Number: 5193
alright thats pretty much what i was thinkin about doing... i was on turbostart.com checking out all there stuff... are those good 16V battS?
Post Number: 7594
listen dumbazz...
go to ebay.. get a external voltage regulator from iraggi 100 bucks...
get a step down 3 volt step down from powermaster...for your electrical..
use a 12 volt batterie with the step down from powermaster
use a 16 volt battery back and wire it directly to the alternator...
thats it.. ull have a 12 volt supply while having a 16 volt system in the back
Username: Safe_cracker
Chicago, IL US
Post Number: 3982
I use two dual voltage 12/16V racing batteries from Jegs and a single BatCap 8400 16V. The BatCap has its own charger so whent they are all hooked up together the one charger takes care of all the batteries at once. I have an Iraggi alt and external regulator but only use it if I do not have access to my charger when needed, I have no dimming at all because it runs fully off the bank. Polo..
Post Number: 5202
ight cool man thanks for the input.
Post Number: 7599
ur not even gonna say to me at least a thanks azzhole?
Chicago, IL US
Post Number: 3991
thanks azzhole^^^^
>Polo
