Polyfill
Username: Sk8terdude2088
FL
Post Number: 12
Hey i built a ported box to kicker specs internal volume is 2.25 cubes and tuning freq is 37 hertz.. Should I use polyfill in the box or not.. and if I should what should i use?
RD 1000.1D with SI MAG...
Post Number: 17087
no polyfill.
FL
Post Number: 13
ok thanks chad!
Post Number: 17089
i hope that box spec is for the 12.
FL
Post Number: 14
Lol yeah its for my l7
Username: 30hrtz
Raleigh, Nc U.s.a
Post Number: 220
ive built that same box and polyfill did help"soften"the sound some.it made it sound cleaner if that makes any sense.maybe alittle more musical.idk but all my enclosures,ported and sealed ive added polyfill after a short time and i seem to like it better.even my AQ 2.5 15 built 4cuft tuned to 40hz sounded better "to me"with polyfill.not a ton but just loosly filled about 1/2 of the box.if you dont like it you can take it out.1.68$ at walmart for a 20oz bag.
Username: Rovin
4 10 Pioneer...
Post Number: 12863
wont cost u much $ to try it ....
