i need help i was cleaning the trunk of my car while playing music when i took out my subwoofers the power cables of the subs touched and system turned off now i turn it on and can hear music but their is a loud beeping noise on all my speakers i checked fuses amps are on and seem ok did i blew a amp ,fuse, cable what? any help please
Pull out the fuses and make sure that they're not blown. Make sure you didn't blow the fuse on your power line. What kind of amplifier is it? It may be worth sending in for repair if it is damaged.
I just comprehended your first post lol and if you're still hearing music through the subs then your fuses aren't blown but your amps may be damaged. I don't know what kind of sound you're hearing and it's hard to figure this out without being in the car diagnosing it.
well the sound is a loud static sound like if their was a bad connection or like a fax sound really loud i mean the amps pick up the speakers well like it used to but now i have this static and its even on for about seconds after i turn off the car completely i plug the 6 1/2 speakers on a home stereo and worked fine. thanks rob for the help i appreciate it.
