3 12" type R's VS. 1 15" BL
Username: Cashby
3 10 Stereo ...
Post Number: 490
wat would get louder, the R's would be sealed and the BL would be fully loaded and ported..and they would both recieve 1500rms. Im just wondering wat will get louder..i no they both sound about the same sq wise..thanks guys
Username: Nd4spd18
Northwest PA
Post Number: 5471
Tough call. I'd get the type Rs though, b/c if you ever did have more room (I assume thats why they're sealed) you could port them and gain output........
Username: Treez
Post Number: 127
Despite the fact that the type R's are sealed, they will be louder on that power.
Username: Cashby
3 10 Stereo ...
Post Number: 491
thanks for your opions guys..i was actually leaning towards the type Rs anyway..and M.S. your right on the space issue..its in a firebird formula (hatchback) and theres not alot of room.
Username: Cashby
3 10 Stereo ...
Post Number: 493
So everyone thinks that 3 type R's would be pretty dang loud in a hatchback??
Username: Treez
Post Number: 128
One determining factor is the tuning frequency of the ported box for the BL.
If it is ported low(31hz and below), the output of the type R's would easily exceed that of the BL.
However, the opposite may be yield indistinct output differences.
Username: Treez
Post Number: 129
Goodluck
Username: Nd4spd18
Northwest PA
Post Number: 5474
^^^ at a loss of low end...... not what you want for a daily system.
Username: Cashby
3 10 Stereo ...
Post Number: 495
ya thats true sean..thank you!
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 7496
type r have to be ported.... if you want sealed the phoenix gold rsd or the octanes zr will do the job alot better than the rs
Username: Cashby
3 10 Stereo ...
Post Number: 496
this mite be a dumb question but wat is a sealed box's tuning compared to a ported, if that makes sense??
Username: Cashby
3 10 Stereo ...
Post Number: 497
Y do u say that zpeedy?
Post Number: 7497
i had type rs in the past and switched them to my pgs
Username: Nd4spd18
Northwest PA
Post Number: 5475
you don't tune a sealed box........
Username: Cashby
3 10 Stereo ...
Post Number: 498
well i no that, but im wondering wat sealed is like compared to in output like of a ported..like how it is projected?? I must not be making sense
Username: Treez
Post Number: 131
Sealed enclosures produces a wider bandwith than ported enclosures and with greater accuracy, but with a reduced output..
Try two 12 rtypes ported on 1500wrms if space is an issue. They will get loud...
Its less hassle with the wiring and buying an amp to match the impedance
Username: Nd4spd18
Northwest PA
Post Number: 5479
Sealed = less ouput than ported
Keep in mind the subs has to be designed for the type of enclosure you're using
Username: Cashby
3 10 Stereo ...
Post Number: 499
zpeedy i just looked at the PG RSD's..they are a good deal..do they get loud?? and how do they compoare to the type R in SPL and SQ..also can they drop down pretty low sealed??
Post Number: 7502
do they get loud??????
http://s79.photobucket.com/albums/j128/extrmndor3/?action=view&current=asda.flv
check the excursion of my ex 70 dollar woofers..... 147 with one wuub unscrewed on youn jeezy air force one on stock electrical with a box tuned to 32hz..
u tell me..
oh mine is the last year model take one put it in a small ported with a good amount of port area and throw 2k and burp it u should see... or try them daily with 800 rms to each one and ull see how they shine
Username: Cashby
3 10 Stereo ...
Post Number: 500
so those are just the octanes huh?? wow, thats nice man..how are the RSD's?? are they a little better then the ZR's??
Username: Treez
Post Number: 132
Decide on your budjet...
If these are the only subs and sizes you plan on using,You should decide on whether you are looking for sq or sql.
This will help you determine the most suitable enclosure and how many subs you need.
If your choices are limited to the BL and the R's ,I would suggest with that stick to the R's
Username: Cashby
3 10 Stereo ...
Post Number: 501
I want 3 subs cuz all ive ever owned as long as ive been in car audio is single 12's (Fi Q, DD3500, MTX9500, type X) and 3 10" SI BM's which are nice but i just dont like the way 10s hit, they sound weird trying to get low so im selling all 3. And my power range is around 500rms each sub..
Username: Treez
Post Number: 133
Colby, if u like ur S.I Bm's then get two 12 Mags or one 15 Mag.
Username: Treez
Post Number: 134
sorry for the spelling.. i meant cody
Username: Treez
Post Number: 135
The mags have a rms of 950wrms and will handle 1000wrms and sound great doing it...
There's quite a few guys on this forums that has used those subs and can tell you that they are excellent Sql drivers.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13588
mags and bms are totally different drivers...
Username: Alpine97
Paramount, California USA
Post Number: 228
I have two type R Alpine's (ported) running on a Memphis ST1000D...it's very LOUD...I could imagine 1 more of them and it would be extreemly loud..trust me
Username: Cashby
3 10 Stereo ...
Post Number: 502
wats ur box tuned to Nick?
Username: Alpine97
Post Number: 248
34hz
Username: •cam•
BC Canada
Post Number: 1661
"34hz"
That tuning may work well in his car, but the optimal tuning for your car is going to be different.
Asking, "Will X sub(s) be louder/sound better than X sub(s)?" is absolutely pointless. Enclosure/cabin add too much in the way of variables. I think that, in the optimal ported enclosure, designed for the car, a properly powered 15" BL could out-bump 3 Type-Rs in a sealed enclosure.
