12w6v2 vs. 12w7
Username: Hamsamich9
Post Number: 28
any recommendations. whichever one i get it will be run off an ALPINE PDX 1.1000 and no matter which one i get, im getting it in the HIGH OUTPUT WEDGE BOX. ive heard that the w6 has better sound quality and that the w7 is only a little bit louder and im not sure i should believe that.
Username: Loudon
Post Number: 2194
ull smoke a dub 6 with 1000 watts daily ... ur power is more suitable with a dub7
Post Number: 29
and there is a possibility of me gettin a second 12w6v2 if i do end up getting the first one. but not for a while
Username: Van_man
Boston South, MA
Post Number: 3258
That amp will be good for the W7, 1000 @ 2-4 ohms. But it will be too much for a single W6, and it wont power 2 - W6's that need 1 ohm amp.
So your choice is clear. Get the W7.
Username: Skibum12189
Cleveland
Post Number: 2387
sell the pdx amp, buy a 500/1 and get the w6 in the HO
Username: Drant19
DUB-C, TX
Post Number: 165
W7
Username: Deadrabit
Post Number: 114
trust me i had a dub 6 v2 running 1000 rms.
it sounds good but after a month it will be fried.
if i were u i would screw jl and get something else.
but if thats really what u want i would go with the w7
Username: Deadrabit
Post Number: 115
if u r going to get 2 W6s do that. two w6s is much better than one w7
Username: Nyyfan13
Fi SSD USA
Post Number: 7845
Post Number: 30
i think im just gonna take the tim to save up for the 13w7 in the prowedge
Username: Drant19
DUB-C, TX
Post Number: 166
13w7 with HO box FTW
Post Number: 31
the highest they go with the HO box is the 12w7 btw and wat does FTW mean.lol
Username: •cam•
BC Canada
Post Number: 1616
For The Win.
Post Number: 33
thats what i thought thanks
Username: •cam•
BC Canada
Post Number: 1620
No problem. Take care, man.
Username: Deadrabit
Post Number: 117
idk... i would go with 2 dub6s!!!!
Username: Alpine97
Paramount, California USA
Post Number: 80
Hey bro I have a 13.5 w7 and it is phenominal. I have been bangin it for about a year now and it sounds just as good as a week after in broke in. LOUD and very nice sound! Trust me, you wont regret it..
