Wiring a Pioneer DEH P6700
Username: Nosloride
Dallas, Tx
Hello
I had a Pionneer DEH-P6400 unit in my 2001 Ford Explorer..It was stolen I picked up a Pioneer DEH-P6700 to replace it..They did not break anything when they took it. will the wire colors from the P6400 match up to the P6700.. I know the second smaller plug is for the factory radio.. Thank you for any help
Username: Kpa2727
Post Number: 833
all pioneers harnes's are standard should be able to plug and play.
