Alpined CDA 9811 for Jeep cherokee infinity gold sound system
My cd changer is broken and I am thinking of putting in a CDA 9811 as the head unti will it work with the 6 speaker system and amp in my jeep as this is only a 4 way radio?
Username: Glasswolf
NorthWest, Michigan USA
Post Number: 3274
you'll need a special adapter to use the factory amp and speakers.
that Infinity system uses amplified speakers and can't be used without the adapter with any source but the Infinity source designed to work with that system.
