Huatai HT800D, dome light problems
Username: Wingdude
Norway
Hello,
I have a Huatai HT-800D alarm fitted to my '98 Ford Econoline E-350 7.3 Powerstroke.
Everything has worked just fine since installation, but recently I have experienced a problem.
After I get out of the car and closing the door, I activate the alarm with the remote control.
The problem that has started recently, is that the alarm doesn't wait for the dome light to switch off before activating, the result is that the siren sounds instantly.
The alarm's operator manual says: the doors will arm automatically after the dome light is turned off.
But it must be pretty obvious that the alarm now activate before dome light has switched off, and therefore belives that there is a door open, and the siren starts sounding. If I wait about 10-15 seconds before activating the alarm after leaving the car, the problem is gone, these few seconds is enough to delay the whole process, and eveything is back to normally.
Anyone who has experienced similar problems, or know what the problem might be ?
Would appreciate all help regarding this matter.
