New radio install
Username: Flattop
Hickory flat, Ms Benton
just installed a sony head unit in a 98 tahoe the speakers in the back doors do not work. i was told that there was a amp behind the glove box but i did not find one. any suggestions
Username: Bnd_rulez
Phoenix, AZ USA
Post Number: 915
Should not have gotten Sony.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 787
^lol
anyway, what you may have is a factory amplifier hidden somewhere in your vehicle. If so, then all you have to do is locate it, and then bypass all the wires. Doing this will make your speakers work again.
If you do not have a factory amplifier in your Tahoe, then your speakers may:
1. Possibly be blown
2. Loose or faulty wiring
