Bronze Member Username: TycoonbobPost Number: 48 Registered: May-07 | Ok, so im buying a scion Xb, wanting a new system to put in it. It will be a daily driver. Wanting 2 12's. wanting it at about 2 ohm on the amp. looking to pay about $800 for 2 subs and amp and box. Brands im looking at right now are DD and audioque. But im not limited to those. What do you think would sound good in the trunk of a scion xb. please help. Thinking about DD9100 12's please also say if I would need to add a battery or not. or any other electrical upgrades needed. I plan to change the alt to about 180-200 amp and do a big 3 upgrade. |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 134 Registered: May-07 | si bm's rd aduio has some good subs and amps sundwon amp kicker ascendant audio arsenals just a few good choices |
Silver Member Username: Talon0112 audioque 2.5 145.2 ..., Pa Usa Post Number: 476 Registered: Jun-07 | what kind of sound sq sql spl also ground pounder or rock |
Silver Member Username: Pbplayer05Carroll, Iowa Post Number: 135 Registered: May-07 | si bm's rd aduio has some good subs and amps sundwon amp kicker amps ascendant audio arsenals just a few good choices |
Gold Member Username: JkidderGunshine , State Flawda Post Number: 2828 Registered: Nov-05 | dd 9112's retail for ur budget so your looking at wrong subwoofer for your budget. we need to know what your looking for. also, dd 9100's are mostly sq subs....if u didnt know |
Gold Member Username: JkidderGunshine , State Flawda Post Number: 2829 Registered: Nov-05 | how much wattage are you looking to run on these two 12's? |
Bronze Member Username: TycoonbobPost Number: 50 Registered: May-07 | well i dont know for sure on the wattage, but prolly around 1500+ but here is a little scenario. there is only about 25 cars in my town with subs. and the best in my opion is 2 12" L7's. and that is exactly what my best friend is also getting. and i know those arnt sq subs, but i want better and louder than my friends. i will up my budget to 1000 to get the subs and amp to get better. |
Bronze Member Username: TycoonbobPost Number: 51 Registered: May-07 | i want a setup thats louder than 2 12" L7s. will spend 1000 on subs and amp if need be. also, what do you all think about fusion subs? |
Silver Member Username: Mj23dynastySome where 12 wangin o..., The Mighty J... USA Post Number: 513 Registered: Oct-07 | RD elites are on sale this month you can get to RE SE's on ebay for like 350 shipped I really want some1 hop on those SE's and you can get a nice amp with the other 450 maybe a kicker 1500.1 depending on the vc config on the SE's if I were you I would go with tht or you can get a budget hifonics amp the SE's and get woodlawn cabinetry to make you a custom box and you'll be in there they will sound waaay better than the L7's I know I had 2 10" at 1 point |
Gold Member Username: CtmikeCt. Post Number: 5449 Registered: Feb-06 | subs: http://cgi.ebay.com/07-WMD-12-subwoofers-handmade-in-USA-COMPETITION-SQL_W0QQite mZ120192445327QQihZ002QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem amps: http://kluvkustoms.com/cgi-bin/online/storepro.php should come to $850 for the subs/amps shipped. |
Silver Member Username: TejcurrentPost Number: 870 Registered: Apr-07 | http://cgi.ebay.com/ebaymotors/Kicker-ZX2500-1-Monoblock-amplifier-2500-watts_W0 QQcmdZViewItemQQcategoryZ38638QQihZ017QQitemZ270192109361QQrdZ1QQsspagenameZWDVW Kicker 2500, That's a bit more power than you were asking for but for about 450 that's pretty fair. Some Fi BL 12's w/cooling would be about 600 shipped, so $1050, or w/out cooling it would be more like 975. We did a swap out from a kicker L7 12 to a Fi BL 12 and the Fi was soo much better sounding, not to mention much louder to the ear. |
Bronze Member Username: TycoonbobPost Number: 52 Registered: May-07 | ya, im liking the wmb,s and the Fi. have you all ever heard fusion subs before? |
