Power acoustik 5500D...
Username: Shade
Moxee, Wa U.S.
Post Number: 482
does this amp do rated power?
i see it claims 3200rms x 1ohm.
anyone have experience?
Username: Rovin
4 10 Pioneer...
Post Number: 12505
seeing that it has 5 30A fuses (very odd) i doubt it will do anywhere near that ...would be a miracle if it even does 1\2 of that ......
Username: Shade
Moxee, Wa U.S.
Post Number: 484
well dude who has it claims he's powering 8 15's with it....and i asked him what he thinks it does, he says he thinks it does 2880rms, kinda random # to throw out.
Username: Loudon
Post Number: 2012
buy one and try it out ... i doubt many people have expiereince with it ...
what are u trying to power with it?
Username: Shade
Moxee, Wa U.S.
Post Number: 485
9515...i just wanna buy something that will power the DD fine
Username: Zacdavis
Beloit, Wi
Post Number: 665
the amp will do 2000rms, plenty for the DD.
dollar per watt its a good deal, make sure you have a warranty, i send back spl's with miscellaneous problems often.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 523
i would get the a3000db ppl say that series is better
Username: Cblaze
Post Number: 524
just my oppinion tho get what ya want
Username: Shade
Moxee, Wa U.S.
Post Number: 490
i'm just looking for a "best" bang for your buck.
it's dual 2, and i need a final load of 1ohm. i got my bxi2006d on it but i wanna purchase something that does about 2400-3000rms. I'm not sure what i wanna spend but i know it's not $500.
Username: Cblaze
Post Number: 530
http://www.sonicelectronix.com/item_6191_Power+Acoustik+A3000DB.html
http://www.sonicelectronix.com/item_9463_SPL+FX1-5500D.html
http://www.sonicelectronix.com/item_9338_--+OVERSTOCK+-60+DISCOUNT+--+Hifonics+B Xi2607D.html
thats alll i can thank of right now.i would get the hifonics 2607d that is the bottom link.thats about the best you are gonna get for under 500 dollars,unless u find somebody on here sellin a used amp
Username: Denali_on_22s
You can call me Scroog...
Post Number: 3129
ill sell you my 2400 watt niche audio amp... same board as treo ssx1500... say 300 + shipping
Username: Shade
Moxee, Wa U.S.
Post Number: 493
output?
Username: Rovin
4 10 Pioneer...
Post Number: 12510
i have seen lots of PA A3000DB in action with no problems - cant say what it really puts out but seen it often on 4 10s pioneer rated 400wrms each & it pounds them really good
that Hif 2607 brutus seems to be a good bang for the $ ....
Username: Shade
Moxee, Wa U.S.
Post Number: 494
what's hifonics actual power?
same rule applies to last years models? 80%
Post Number: 3135
2400 @ 1 ohm, 1200 @ 2 ohms, 600 @ 4 ohms
Username: Mmaudioconcepts
Murray, KY
Post Number: 311
that PA puts out like 1700wrms
