Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 16 Registered: Nov-07 | Just trying to get every ones opinion on the top 5 15 in Subs for a 1000 watt amp??? Since i was original go with some kickers but now i think i may get something else and i need yall opinion ??? |
Silver Member Username: Philly306North carolina Post Number: 531 Registered: Apr-07 | sooooo many variables and people's opinions. |
Silver Member Username: SomedonniedudeIllinois United States Post Number: 398 Registered: May-07 | What are you looking for in a sub? Sound quality, SPL, best of both? What kind of vehicle is it going into? Do you have a price range? |
Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 17 Registered: Nov-07 | It is going into a Jimmy 2001, i would like something that is clear but still with a great bass and no distortion that will last a wile . |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 2... Post Number: 5522 Registered: Mar-04 | A DD2515 would be nice. Nice clean, quick bass that can drop LOW. Should be mean in that Jimmy ![]() |
Gold Member Username: The_image_dynamicSan Diego Post Number: 3091 Registered: Dec-06 | SoundSplinter RL-S |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 806 Registered: Mar-07 | buy one of chad's^^^ |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13157 Registered: Jul-05 | budget?? |
Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 18 Registered: Nov-07 | Not realy any budget as long as it is under 650 for the pair. |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13158 Registered: Jul-05 | so u want 2 15"subs on 1000rms?? what kind of amp do you have?? |
Silver Member Username: Press1Yuba City, CA USA Post Number: 308 Registered: Nov-04 | So really you want 2 - 500 watt subs? for your 1000w amp? |
Silver Member Username: Press1Yuba City, CA USA Post Number: 309 Registered: Nov-04 | Chauncey you beat me to it...lol |
Silver Member Username: Big_edge_headMilwaukee, Wisconsin USA Post Number: 807 Registered: Mar-07 | 2 15'' SD2.5s |
Platinum Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 13161 Registered: Jul-05 | ^^^They dont hit the lows very well...get really loud tho and sound decent |
Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 19 Registered: Nov-07 | Kicker ZX 1000.1 and YES . |
Silver Member Username: Philly306North carolina Post Number: 532 Registered: Apr-07 | AA arsenal |
Silver Member Username: Hurricanebr1anWestern Burbs of Chicago, IL Usa Post Number: 223 Registered: Sep-07 | Since thats pretty low power, I'd suggest Maw 15s and get a nice box from fishercustoms. Could be had for well under $500. |
Gold Member Username: LoudonPost Number: 1983 Registered: Jun-04 | rd sonance |
New member Username: Vtouch06Post Number: 2 Registered: Nov-07 | New AQ HDC315 i just bought one and running im going to run it off the same amp. |
Gold Member Username: JkidderGunshine , State Flawda Post Number: 2685 Registered: Nov-05 | he needs 2 15's vt..... |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 2... Post Number: 5530 Registered: Mar-04 | Do you want to stay under the window line in your Jimmy? IIRC, you really dont have room for 2 15's in a Jimmy and stay under the window line. But...if you do, 2 DD1515's would be mean. I got 139.5dB out of a pair in a Yukon at 41hz w/ only 300wrms!!! Run a pair on that zx1000 and they will come alive! |
Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 20 Registered: Nov-07 | Wear would be the best place to purchase 2 DD1515`s ??? |
Gold Member Username: JohnfiacA-ToWn, 9515 thumpin... What u bumpin? Post Number: 3858 Registered: Mar-06 | "Not realy any budget as long as it is under 650 for the pair" thats a budget then, my last set of subs was 2x that |
Gold Member Username: SouthernrebelMonroe, Louisiana 2 DD3515s, 2... Post Number: 5534 Registered: Mar-04 | Go to: www.ddaudio.com Use the dealer locator to see if there is a dealer near you. If not, call up DD and order them direct. |
Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 21 Registered: Nov-07 | KiLLa :"Not realy any budget as long as it is under 650 for the pair" thats a budget then, my last set of subs was 2x that I dont realy care.... |
Gold Member Username: Th3pwn3rPost Number:... Post Number: 5895 Registered: Jul-06 | He was just point out your budget.And yea...DD isn't cheap,Killa paid 650 a piece for his 9515Fs.That's a deal of a price too... |
Bronze Member Username: Tpa954Hollywood, Florida U.S.A Post Number: 22 Registered: Nov-07 | So i if i can get a pair for around 300 get them correct , but they are used . They are from a family member so i know they are in good condition . |
Bronze Member Username: Tblazer74South Salem, NY USA Post Number: 67 Registered: Jun-07 | Ill pay you 375 + shipping for them if you get them for that. |
