Weird noise from subwoofer (voo noise)
Username: Sparkz
Hi all,
I got pioneer 1200W TS-W257D2.
just installed it few days ago and i hear a weird vooo (simillar something vibrating) coming from the port of the subwoofer's box.
now i checked the box it's perfectly as i see it .
what could be the problem ?
Username: Th3pwn3r
Post Number:...
Post Number: 5866
Are you sure you're not getting alt whine or ground noise?Does the sound of the noise increase or change as you press on the gas?
Username: Loudon
Post Number: 1981
ur hearing it come from the port of the box?
perhaps port noise? lol
what type of box? was it made to woofer specifications or is it a prefab?
Username: Sparkz
it's prefab and yes it's coming from the port of the box and it's really annoying during high volume.
here is a picture of my sub with it's box.
it's a simple box i think it's the cheap kind.
but i wanna be sure it's the box before i buy a new one.
http://img136.imageshack.us/img136/3391/img1980lb3.jpg
Username: Nyyfan13
Fi SSD USA
Post Number: 7027
am i the only one who doesnt see the port lol
Username: B3n07
Louisville, Ky USA
Post Number: 581
i was woundring the same thing maybe hes callling the terminals the port lol
Username: The_image_dynamic
San Diego
Post Number: 3090
The box says bandpass on it...
Username: Sparkz
the port is on the other end of the brown wall .
Username: Yukhui
3 15 AA Havocs, Memphis 4kw!!
Post Number: 775
Let's see a picture of the port?
Username: Sparkz
ok ....
http://img265.imageshack.us/img265/7559/img1984pw4.jpg
http://img265.imageshack.us/img265/7289/img1986it2.jpg
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13159
turn off all of ur bassboost,eq,etc...then turn up the volume does it still happen??
Username: Logan__tille
HEMIKLR
Post Number: 9066
Check and see if your amp has a clean ground.
Username: Van_man
Boston South, MA
Post Number: 3085
take that grill thing out of it. Inside the port
A pic is worth 1000 posts!!
Post Number: 11101
WTF is that crap in the port?
Username: B3n07
Louisville, Ky USA
Post Number: 583
are you tring to process food with your sub cuz that port looks like a food grinding thing
Username: Nd4spd18
Northwest PA
Post Number: 4107
Prob port noise. Not surprising at all since prefab boxes really suck.
Username: Hdubb
Team Revolution
Post Number: 2877
how much power is thed sub getting? the new premier subs with the air suspension make a funny noise when get to full excursion. but more then likely port noise. =/
Username: Hdubb
Team Revolution
Post Number: 2878
you might try taking the whole port out and buying a new one at partsexpress
Username: Sparkz
the sub is getting 230 RMS at 4 ohm right now .
the grill is part of the port should i try and cut it out ?
Logan what do u mean by clean ground ? it seats on the floor of the trunk .
http://img337.imageshack.us/img337/764/img1981ze1.jpg
http://img337.imageshack.us/img337/787/img1980gt4.jpg
HEMIKLR
Post Number: 9068
Just make sure all the paint is cleaned off, and its just bare metal. S
Username: Hdubb
Team Revolution
Post Number: 2883
hes talking about the grd wire from your amplifier. yes try cutting it out.
Username: Johnfiac
A-ToWn, 9515 thumpin... What u bumpin?
Post Number: 3868
its a prefab box; either way u should get a new one; but this time somthing at good specs for that sub universal boxes always suck
Username: Sparkz
u mean making sure no plastic is touching the connections ?
i might be buying a new box today it's also prefab but my buddy has a pioneer 1000W on it and it sounds great .
Username: Sparkz
Post Number: 7
U guys sure it's the box ?
it's the kind of noise u get when u blow on paper from the side coming out of the port..
and if i want to build a box where do i get the measures ?
Username: Sparkz
Post Number: 8
up ... =|
Username: Sparkz
Post Number: 9
up ...
HEMIKLR
Post Number: 9071
Is it all the time, or only at high volume?
