Sup Placement in my wagon BEYAHHHHHH HA HA
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1695
18"FI q
cant let face forward cant see out window
so? so crx style sub up port back
or forward???? what will work best overall
or does it even mater?????
12 cubes 28hz
Username: Nyyfan13
Fi SSD USA
Post Number: 6879
first off, thats badazz killer....hurry up and get everything so i can hear it lol
subplacement, i couldnt tell you....i would do sub up port back but that has no reasoning behind it so take that as you will lol
Username: Hdubb
Team Revolution
Post Number: 2773
i say either crx style or sub and port up. both seemed to do ok for me. =)
A pic is worth 1000 posts!!
Post Number: 10956
18" Q in a CRX.
WOW man. Have fun.
The bass gods are clapping.
Username: Safe_cracker
Chicago, IL US
Post Number: 3754
Ya but it is at 28hz so it being directional probably won't be the case so aim it as you wish. You may want to be carefull at that frequency those subs are known for having tinsel issues and overexcursion can happen much more easily at lower frequencies, watch yo power! Polo..
Post Number: 1696
NO paul
18 Q in a 92 Caprice wagon
and yeah POLO thats what happended to my TSX it was loud down low but i think it over excurted nd died LOL im going to get the BP option 400more watts i belive helps the coil but not the excursion part hmmmmmmmm
Username: Insearchofbass
Post Number: 7015
well one thing I noticed in my bro's suv was that the 15 was more forgiving on the meter firing up port up than the 12 was and they both were in the same box we just cut out the hole for the 15 to fit so I think your 18 will do fine that way too....so fire port up sub up...I think the having them both there will build pressure better
Post Number: 1698
thats what i was thinking any more oppions??
Post Number: 1700
thats what i was thinkin i might just do that then any1 else gotta an opion??
