Which sub should i get
Username: Igor_xxx
OK, first i am on a budget and i need something just to hitt good and theese are my options
pioneer ts-w307d2
kenwood KFC-W3011
both of them are 400rms but some guys tell me that the kenwood can handle 100rms+ so it's my favourite but I need your opinion.my amp will be in the 300-500watts RMS range (most likely around 500rms).thanks
Username: Cenus
Ohio
Post Number: 3756
pioneer, kenwood sucks. for an amp look into kicker, mtx, hifonics, PG, that fit your needs.
Username: Insearchofbass
Post Number: 6975
whats your budget maybe we can help you get something better
Username: Igor_xxx
For my sub i plan around 120-150$ but the problem is that in my country (macedonia) i can't order anything online.most used and only availible brands here are kenwood,pioneer,jbl,alpine,blaupunkt,focal etc.My other choice will be JBL for that price but whats your opinion.
and here is one page that maybe help you to see whats on the market here
www.autoland.com.mk
and for the price 50den=1$
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 795
you can pick up an alpine type r for around 110-120 dollars
Username: Cenus
Ohio
Post Number: 3758
try to find a cheap alpine sub, then look for a alpine or jbl amp, those are the only brands i would get that you have to choose from.
Username: Igor_xxx
Post Number: 7
Yes I can find samo brand new and cheap alpine and jbl sub, but it will loose the power but the quality will be better then the kenwood or pioneer, right?i am not some power freak, i just want quality bass
Username: Cenus
Ohio
Post Number: 3761
yes alpine and jbl are much higher quality than pioneer and kenwood IMO.
Username: Cblaze
Rock island, Tenesssee Us
Post Number: 332
dont try kenwood
Username: Rovin
4 10 Pioneer...
Post Number: 12461
go with the alpine type R if falls into your budget ....
Username: Igor_xxx
Post Number: 10
yes i will go with alpine or jbl just the cheapest type-r here is 200$.what do you say about the other (cheaper) alpine types like L,E,S?are they good enough?are they quality?
Username: Nd4spd18
Northwest PA
Post Number: 3613
Only good Alpine is the Type R
Username: Igor_xxx
Post Number: 12
What about JBL subs?someone have experience with them, how do they hitt and sound?
