Best Setup For 300$$$$
Username: 420pimp2
Post Number: 808
I am looking for the best spl system in your opinion if you only had 300$. You will need to buy 2 12 inch spl subs and one amp to power them all for 300$.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 13062
Just $300???? I would save now shine laidher
but if i had to...some kicker cvr's and a audioburn A8000T or whatever there 800watt amp is...
Username: Tejcurrent
Post Number: 732
Two Fi type-x's (160 shipped) and a that audiobahn amp, or maybe this:
http://cgi.ebay.com/ebaymotors/NEW-LANZAR-2-CHANNEL-2000w-CAR-AMPLIFIER-STEREO-S UB-AMP_W0QQcmdZViewItemQQcategoryZ38638QQihZ008QQitemZ180175198919QQrdZ1QQsspage nameZWDVW
I'd save up a bit more cash and get a bit more quality.
Username: 420pimp2
Post Number: 809
I would like to get a deal on 2 12 type r's and a kx 1200. Fu.ckin amps are so expensive thoe. Any resolution for an amp that is alot cheaper and still will power two type r's to there full potential?
Username: Killswitchjd
Post Number: 686
365$ Elemental designs nine.1
at 1 ohm
Username: Budling
Cali USofA
Post Number: 343
295$ for the nine.1
Username: Somedonniedude
Post Number: 337
You can grab some 12' cvrs off of ebay for bout $150 shipped and a hifonics zxi1006 for about $240 shipped. Then build the box yourself about $35.
or instead of a hifonics you could get a refurbished kicker zx750.1 for $200 shipped.
How loud are you wanting it or what systems have you heard before that were loud enough?
Username: 420pimp2
Post Number: 811
Just as long as it hits good and sounds nice. Two type r's will be fine.
Post Number: 737
Type-rs will consume almost all of the budget you've set for the whole setup. If you could get a hifonics 1006 for 240 and those Fi Xs for 160 that's an exact match to what you were wanting.
Post Number: 738
Type-rs will consume almost all of the budget you've set for the whole setup. If you are willing to increase the budget you would have many more options.
Username: Cenus
Ohio
Post Number: 3754
AA arsenal and mtx 801d, i think the arsenal is $200 on ssa, and the 801 goes around 200 on ebay.
