Bronze Member Username: TycoonbobPost Number: 41 Registered: May-07 | Alright. Im redoing all my stuff, and I want some suggestions. What I want is: -HU with approx 7" fold out screen -12" subs, approx 500-600wrms __ x2 -amp to power them Do have a budget, cant really say how much cause idk...just not to extremely expensive. I drive a 2 door hatch back focus zx3, and I want SQ over anything else. And I want it to hit HARD. Also, if you can, please try to post prices if possible. |
Gold Member Username: CtmikeCt. Post Number: 5357 Registered: Feb-06 | i'd do a pair of boston g5 12"s with a sundown sae1000d. and for hu an alpine iva-d310. msrp for all that should come to about $2100, but that's msrp. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 3881 Registered: Nov-05 | you contradicted yourself.. "I want SQ over anything else. And I want it to hit HARD." that would be SQL.. what is it.. SQ, SQL, or SPL .. and you really might want to post your budget of "not spending too much" because this can go a direction you don't want it to go |
Gold Member Username: LoudonPost Number: 1850 Registered: Jun-04 | i drive a focus hatch ... panasonic cq7001u 7 inch 15 inch alpha sundown 1500d boom bout 1600 bucks or so |
Bronze Member Username: TycoonbobPost Number: 42 Registered: May-07 | Well for a HU, Im looking for like 350-450 max...total I wanted at less than $1000...Using all stock electrical |
Bronze Member Username: TycoonbobPost Number: 43 Registered: May-07 | SQ is what I want, but I want it to hit noticably hard from a distance. |
Gold Member Username: HdubbTeam Revolution Post Number: 2698 Registered: Nov-04 | x2 with mike. ive seen some people talking about a really inexspensive head unit. the name escapes me at the moment. cal payne has one and zac sells them i believe |
Bronze Member Username: TycoonbobPost Number: 44 Registered: May-07 | well if you can think of the name, please lmk...i really want a touch screen hu single din |
Gold Member Username: LoudonPost Number: 1851 Registered: Jun-04 | look for that panasonic pal |
Silver Member Username: Kyle_lowePost Number: 517 Registered: Apr-06 | i think for the wattage that you want to run, ou should upgrade your charging...even though you didnt want to. |
New member Username: Mj23dynastyHarrisburg (star city), Pistolvania USA Post Number: 6 Registered: Oct-07 | Go with a jensen touch screen with 2 12 in alpine type r on a rockford 500/1 or an audiobahn A800T... I got a jensen touch for sale ill let it go for 400 I got pics and if you have any questions email me MJ23dynasty@tmail.com |
Gold Member Username: LoudonPost Number: 1867 Registered: Jun-04 | honestly ... there is no jensen touchscreen thats worth 400 dollars ... even the touch screen make sure u do upgrade ur electrical somewhat .. u should be ok with a good batt up front and the big 3 upgrade.... i run a sundown 1500d on my stock alt .. very minimal dimming if ne at all .. and its only at idle ... also be sure to deaden the car ... without this the hatch tends to rattle hardcore |
Gold Member Username: InsearchofbassPost Number: 6878 Registered: Jun-04 | can it be ebay (new) or does if have to be online stores |
Gold Member Username: InsearchofbassPost Number: 6879 Registered: Jun-04 | I agree with Mike dont buy the Jensen |
