does anybody know how? im helpin a friend and dont know how to uninstall the stock deck and cant manage to find out how to take out the dash... diagram or links would be nice
i've done it before...the whole dash pops off in one piece....find the seam of the dasy and start on a cornor you can use a small flat head screwdriver and prise real gently...dont scratch the dash....the screws for the factory head unit are behind the dash
up above the gas and brake peddle and see if you can see a rubber grommet....pull it out and you should be good.....i didnt install a amp wire...i put a cd player in for a chick she didnt have any bang to go in...
