Username: 94_toy Post Number: 59 Registered: Sep-07
Thursday, October 11, 2007 - 17:59 GMT My buddys got a kicker zx750.1 (same as me) and he wants to get a sub. hese got his heart set on (2) 10" kicker comp vrs or 1 12" alpine type-r. Which would be the louder sub/s.
Username: Killswitchjd Post Number: 681 Registered: Apr-06
Thursday, October 11, 2007 - 18:01 GMT With only 1 sub is your best bet. 750 will do fine but to make sure it bumps I would get one sub in a nice box... people can give you better cheap suggestions on here im sure
Username: Loudon Post Number: 1795 Registered: Jun-04
Thursday, October 11, 2007 - 18:07 GMT a type r and that amp will sound good ... plenty of power ... those subs shine in a ported enclosure .. build it to spec and ull be good
Username: 94_toy Post Number: 60 Registered: Sep-07
Thursday, October 11, 2007 - 18:20 GMT louder than the two tens? i was leaning towards the type-r too
Username: 94_toy Post Number: 61 Registered: Sep-07
Thursday, October 11, 2007 - 18:22 GMT birthsheet on my 750.1 says 904 Watts rms though, thats like 400 over wat the alpine is. Just dont go crazy with the bass knob??
Username: Insearchofbass Post Number: 6713 Registered: Jun-04
Thursday, October 11, 2007 - 19:51 GMT I personally think 900 rms will be too much id say no more than 800 rms on the type r 12
Username: Insearchofbass Post Number: 6714 Registered: Jun-04
Thursday, October 11, 2007 - 19:52 GMT and no bass knob used on the amp
Username: Kyle_lowe Post Number: 450 Registered: Apr-06
Thursday, October 11, 2007 - 20:03 GMT talk him into a ss rlp 12
Username: Logan__tille Team Revolution
Post Number: 8986 Registered: Feb-06
Thursday, October 11, 2007 - 20:53 GMT Type R
Username: Clouduz Post Number: 220 Registered: Jun-06
Friday, October 12, 2007 - 02:01 GMT Type R won't be disappointed with a good box just don't expect too much if you get a prefab box
Username: B3n07 Louisville,
Ky
Post Number: 401 Registered: Jul-07
Friday, October 12, 2007 - 02:53 GMT get the cvrs they will get real loud i have my two hooked up to 600 watts each and there awsome loud
Username: Rovin 4 10 Pioneer...
Post Number: 12342 Registered: Jul-05
Friday, October 12, 2007 - 03:41 GMT note he said 2 10s or 1 12 if was 1 12 type R vs 1 12 crv then the R will kick its azz easily but IMO would say the 2 10s will be louder than that 1 12 .......
Username: 94_toy Post Number: 63 Registered: Sep-07
Friday, October 12, 2007 - 05:47 GMT now he wants (4) alpine type-e's....that will belouder than the comp vrs right???
Username: Joebruce 15 AQ HD3
Post Number: 1530 Registered: May-04
Friday, October 12, 2007 - 08:43 GMT type e's suck man. tell him to go with some SD2.5 from Audioque. hell if he can fit 2 15s then go with 2 15" SD2.5s,if not then 2 10s or 12s will sound nice
Username: Clouduz Post Number: 221 Registered: Jun-06
Friday, October 12, 2007 - 22:56 GMT stay away from the type e if you want to be loud i concur they suck
