CVX 15 OR CVR?
Username: Sqhoe
Huntington, IN USA
Post Number: 54
Looking for SQL, which would do better with 900rms? 1 ported CVX 15(3.5cubes@30hz) or 2 CVR 15's sealed at 2.5 cubes each. Looking just for music so extension below 30hz isnt all that essential.
Username: Hurricanebr1an
Western Burbs of Chicago, IL Usa
Post Number: 138
i'd go cvx, i have a 12 ported and the sub hasnt disappointed me. cvrs are much better ported than sealed.
do u have to go kicker though? budget?
Username: Spivey17323
Dunellen, New jersey United states
Post Number: 605
ryan if u need an amp i have a kicker that does close to 900 rms at 2 ohms. terribletowel16@aol.com
Username: Sqhoe
Huntington, IN USA
Post Number: 56
I already have an amp, its a Zx750.1. It benched at 924 @ 2 ohms. It doesnt have to be Kicker either. I have a Diamond D6 15 thats ported, 3 cubes @ 32hz, but I want to try something different. The Diamond is too peaky for me. I want something smoother that will play a little higher. Right now it has a large peak in the 32-55hz range and it just doesnt blend well. I am really looking for something louder and able to play a broader range 28-80hz ish without the peak.
I have modeled the CVX on WINISD and it looks as if it would play louder and lose the peak. I am open to other suggestions though.
Trying to work on a budget of around $250, ebay is fine.
Post Number: 606
lol oh ok i see
Post Number: 139
cvx 15s go on ebay refurbished for 170 i think.
Username: Sqhoe
Huntington, IN USA
Post Number: 57
Anyone have experience with a 15" ported CVX?
