SUB BOXx ..
Username: Joelrobichaud360
Bouctouche, New-Brunswick
Post Number: 30
What would be the space requirement for a 12" sub inside the box ??
Username: Ctmike
Ct.
Post Number: 5240
around 6cuft.
Username: Nd4spd18
Northwest PA
Post Number: 3260
It depends on the sub. But thats way to high ^^^^^
Most 12s should take around 3 cu.ft.
Username: Jtown
ATX, Texas
Post Number: 441
but he means, inside the box. as in the sub is in the middle of the enclosure, you can't see it without some plexi...I'm assuming....
Username: Rovin
4 10 Pioneer...
Post Number: 12264
if he is asking whats the typical cuft which most 12" uses - then its about 2-2.5cuft after displacement......
Username: Jkidder
Gunshine , State Flawda
Post Number: 2087
.16 cu ft is he askin displacement? lol
Username: Nyyfan13
Fi SSD USA
Post Number: 6304
i think ctmike was giving a dumb answer cause the OP asked such a dumb question.....just a thought
but joel, what sub is it? sealed or ported?
Username: Ctmike
Ct.
Post Number: 5251
correct^^.
Post Number: 31
sealed ..just whats a tipical box for a 12"????
Username: Nyyfan13
Fi SSD USA
Post Number: 6308
about 1cuft - 1.5cuft
Username: Nd4spd18
Northwest PA
Post Number: 3273
^^^^ Thats about right
