Username: Dubmc23 Rapid City,
SD
Post Number: 6 Registered: Sep-07
Monday, October 01, 2007 - 20:49 GMT i already have one kicker 15" cvr with a zx750.1 amp..should i get another 15? or goto 2 12's? if so what type of 12's would go well with the amp?
Username: Kyle_lowe Post Number: 389 Registered: Apr-06
Monday, October 01, 2007 - 20:53 GMT are you getting another amp?
SD
Post Number: 7 Registered: Sep-07
Monday, October 01, 2007 - 20:56 GMT probably not since money is pretty tight but possibly in the future...
Username: Hurricanebr1an Western Burbs of Chicago,
IL
Usa
Post Number: 108 Registered: Sep-07
Monday, October 01, 2007 - 21:28 GMT if money is tight, why are you asking about a different setup? for 2 12s i would recommend audioque SD 2.5s at $150 a piece or 2 maw12s at $100 a piece. Both are around 400-500wrms a piece, would work well with a 750 (850wrms i'm guessing).
Username: Sqhoe Huntington,
IN
Post Number: 51 Registered: Mar-07
Tuesday, October 02, 2007 - 12:44 GMT Why do you want to get another sub? Not loud enough? Are you running sealed or ported?
