Gold Member Username: 420alldaylongPost Number: 2657 Registered: Sep-06 | What single 18" sub did he hit 180.5db? I know he used 4 Stetsom 7K D. Thanks |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1698 Registered: Dec-06 | DDZ 18" |
Gold Member Username: 420alldaylongPost Number: 2659 Registered: Sep-06 | Thats what I was thinking.^^^^^^^^^^ Amazing |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1699 Registered: Dec-06 | Those subs have some balls |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3508 Registered: Jan-06 | Who's Alan Dante? |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1700 Registered: Dec-06 | the man |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1701 Registered: Dec-06 | http://www.caraudio.com/forum/showthread.php?t=255942 |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3509 Registered: Jan-06 | I know who he is, almost bought one of his Z2 amps with his signature! >https://www.ecoustics.com/electronics/forum/car-audio/389777.html |
Gold Member Username: JkidderIA, DP RD Post Number: 2003 Registered: Nov-05 | i heard the dd z was quad .7 ohm and he ran each of the stetsom's at .33 on each coil. do you know if thats true polo? |
Gold Member Username: JkidderIA, DP RD Post Number: 2004 Registered: Nov-05 | .35** sry |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3512 Registered: Jan-06 | Chances are it is! It is unbelievable what they are running those amps at. I do know for a fact they were running the Z2's that low and they wonder why they have to replace fets so often, lack of battery power, lmfao..Polo.. |
Gold Member Username: JkidderIA, DP RD Post Number: 2006 Registered: Nov-05 | i doubt alan dante had the same problem in lack of battery power as the other competitors. he runs some sick batts |
Gold Member Username: Snarl2004Audioque 12 SD2.5s, Earthquake P... Post Number: 1703 Registered: Dec-06 | "i heard the dd z was quad .7 ohm and he ran each of the stetsom's at .33 on each coil." isnt he running 4 stetson amps? If so and he put one amp on each coil that would be .7ohm load on the amp right? |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 3513 Registered: Jan-06 | Or .175 Polo.. |
