Bronze Member Username: DeadrabitPost Number: 87 Registered: Jun-07 | i am making an other box for my freinds 12inch brutus. its nothin great but i really want to make this a good box. i got this thing off the site but then i after talking to my freind an competive caraudio he thinks that 35Hz would be better than 31Hz. SoOoOo thats what i am going to do. i already had the box started with this design. but for some reason i can't get subwoofertools.com to work for me and i cant uploud anything to figure Hz cause i have vista and its for XP and like win 98 and stuff. so can anyone tweek this design so it will be at 35Hz and not 31Hz? please and thank u! this is the sub BX12D2 12-Inch 2-Ohm DVC Driver Theile & Small Parameters: WRMS = 600-Watts U = 2-Ohm + 2-Ohm Fs = 31.05 Hz Qts = 0.433 Vas = 47.39 Liters Xmax = 15mm SPL = 95.77dB @ 2.83v this is the design i have now http://www.putfile.com/pic.php?img=6600214 |
Bronze Member Username: O0airjordan120oMN US Post Number: 68 Registered: Sep-07 | watprogram did you use to deign that?? |
Gold Member Username: InsearchofbassPost Number: 6552 Registered: Jun-04 | if that is 1.50 cubic feet net your tuning in that diagram would be 32.63 hz ....your port length is 28.5 plus end correction for one turn in the port which would be .875 = 29.375 using a 1.75 wide port |
Gold Member Username: InsearchofbassPost Number: 6553 Registered: Jun-04 | 11.5 x 1.75 port from what I understand the port size to be on the diagram |
