Kicker ZX1000.1 or ZX1500.1 for a 18" Q
Username: Trans_am_ls7
Lincoln, NE
Post Number: 77
shoud i get the bp for the sub???
Lincoln, NE
Post Number: 78
pump
Username: Ctmike
Ct.
Post Number: 5218
don't you mean bump? but i would just get the zx1000, it'd be perfect for it.
Lincoln, NE
Post Number: 79
yea mybad now how do i do a 2ohms load on a 1ohm sub???
Username: Ctmike
Ct.
Post Number: 5219
you wire a dual 1ohm sub the same as a dual 4ohm.
Username: Hgihkcin
Lincoln, NE
Post Number: 264
if you have a dual 1 ohm sub and you want 2 ohms wire it like this,
to amplifier posotive____+-______+-____to amplifier negative
Lincoln, NE
Post Number: 80
u got me so lost in dat pic lol do u got aim
??? mine is kingandsons07
Username: Somedonniedude
Post Number: 280
Do you know what series wiring is? Its when you take the positive line from the amp and connect that to the positive on one of the coils. Then take the negative from the amp and connect it to the negative on the opposite coil on the sub. Then you should have an empty negative on one coil and an empty positive on the other. Connect those two (positive and negative) with another seperate wire. That is series wiring and will make a 2ohm load with a dual 1 ohm sub.
Username: 420alldaylong
Post Number: 2640
Trans Am LS7
Get the Fi Q 18" dual 1ohm with BP power option and the Kicker ZX1500.1
Lincoln, NE
Post Number: 83
thanks! thats what i'm thinkin of doin
