OT Waxing a Car
Username: Skibum12189
Cleveland
Post Number: 1726
I've never really waxed my car, but i refuse to take it through a car wash....
i generally wash it once a week but i want to wax it...i was thinking some of the spray on, wipe off (no buff) spray waxes, but idk much about em
any tips on waxing??
what differences will i see?
Username: Naledge503
Http://com4.runboard.c...
Post Number: 1848
Use a carnauba wax. one that you wipe on and wipe off. You will want to put it on in little swirls about 2inches wide each swirl. Do one section of the car at a time and dont do it in the sun.
Post Number: 1849
Oh and wash your car before you wax it.
Username: Killerzracing71
Fredericksburg, Virginia United states
Post Number: 1597
its gonna take some time but its worth it itll make ur car look real good ohhhhh and dont get sumthing with like 100% carnuba thats expensive (not like ull find it round here either)
wax on wax off....
u let it sit till it turns white then wipe it off.....
oh an i dont do one section at a time i wax tha whole car.... then whip it off in that same oder.....
okay thats was a long enough rant im out
Username: Gavbo211
JL Audio 10w3v2, IL US
Post Number: 589
yeah don't use spray.. take the time and go ahead and give it a nice wax. if you wash it once a week you will be amazed how much easier it is to wash after you wax it. just out of curiousity what color is your car?
