Username: Dub_c Post Number: 309 Registered: Mar-06
Sunday, September 16, 2007 - 01:19 GMT Does anyone how this setup will sound with about 800wRMS?
Username: Northomaha Post Number: 562 Registered: Mar-06
Sunday, September 16, 2007 - 01:22 GMT It should sound good. I would still port it. Especially with that much power. is it a 12 or 15?
Username: Rovin 4 10 Pioneer...
Post Number: 12186 Registered: Jul-05
Sunday, September 16, 2007 - 01:24 GMT when i had my 2 type i had them each in 1 cuft & it sounded quite good off a power acoustik amp rated 2100wrms .......
Username: Dub_c Post Number: 310 Registered: Mar-06
Sunday, September 16, 2007 - 01:25 GMT I wish I knew how to make enclosures, it will be a 12", does anyone know of a place I can get a ported box that will work with that sub?
Username: Surferdude9371 Fully loaded 18 BTL
Post Number: 246 Registered: Mar-07
Sunday, September 16, 2007 - 01:30 GMT ur best bet is there are alot of talented box makers on here like logan post that u need a box made and youll get a bunch of responses im sure and shouldnt cost you that much for 1cuft box
Post Number: 12187 Registered: Jul-05
Sunday, September 16, 2007 - 01:36 GMT u can always buy a 2cuft sealed prefab & port it with a 4" aeroport ...
Username: Dub_c Post Number: 311 Registered: Mar-06
Sunday, September 16, 2007 - 01:37 GMT Naw I can get a good 1 cu sealed box almost anywhere, I'm wondering about a ported box that will work with the Type R. ALSO, for a sealed box, will it make a sound difference if the box is 1.2 cu or 1.6 cu sealed?
