Pioneer
Username: B3n07
Louisville, Ky USA
Post Number: 210
Ok so i just burned diary of jane i reall wanted to hear it on my system threw the cd in listen to my for 15 seconds and then it made this horrible noise like all my speakers were blown so i threw in another cd and it started off good and went to sounding the same could some one help me what has happened to my HU
Username: Extrmndor3
Post Number: 6616
check your ground... also check your rcas if your using external amps..
if your using an aftermarket cd player and then a wiring harness and with no separate amp... the problem might be that you have a factory amp and your headunit is sending super strong signal to the factory amp....
if not it might be something fucked up on your cd player
Username: B3n07
Louisville, Ky USA
Post Number: 212
i unplugged the HU and now its working perfectly i dont know what was wrong but then again we have been have some extremely hot weather latly could that be the reason
Post Number: 6619
DUDE READ THE MANUAL....
it migth be that yoru equlizer was all full........ and it got stored everytime u install your headunit and everything u need to reset it with the reset buttom read the manual
Username: B3n07
Louisville, Ky USA
Post Number: 216
ok i read the manual it had nothing in there to deal with this problem my eq i keep set at flat all the time
