Hurry.... can i do this..??
Username: Blainew
Post Number: 2547
can i cut RCA's and splice them back together???
will it lower SQ?
Username: Thed42
Post Number: 82
Sure can, just make sure you connect them well.
Soder and shrink wrap it
Username: Drivingreckless
DD 9515f, 148.2 db Mov...
Post Number: 3940
i dont see why not but why would you wanna do that??
Username: Th3pwn3r
Post Number:...
Post Number: 4199
He's probably going to run them through a small hole and then hook them back together or he's going to split them into multiple terminals.
Username: Blainew
Post Number: 2548
after i posted this i realized that i can do it..... its just wire...
but anyway rob is right.... im running all my wires through MDF and i want to cut the smallest holes possible
Username: Jtown
Post Number: 206
You could not splice the wires and just cut a whole for that size thats appropriate and then silicon the hole...I understand it will be bigger, but get the right silicon and all it will look like is the wires coming out of the box with no real visible hole.
Username: Santa_fe
Post Number: 44
yo blaine i did this with my system....it doesnet sound any different...i had to cuz i got my amps in a box and hade em all wired but forgot about the RCA jacks and dident want to life up carpet unscrew 8 screws just to put the rca cables in a lil hole...soo yeeaa you will be fine
Username: Blainew
Post Number: 2555
okay good.....
to paint a picture for all of you
my amps are on a piece of wood, in a compartment in my car, you lift the door, you see the amps and the wires. so i want to raise that wood and make all the wires go directly into it, and it is carpeted, so i want small holes...
