Kicker 15 L5 serial or parallel?
Username: Ricez
Post Number: 25
Hey everyone,
I have a Kicker L5 15", I am wondering if it is best to put the impedances in serial or parallel since the woofer has dual voice coil (each 2ohm). I know that the less the more ohms, the better. But what is recommended for a Boss GT1500D amp?
Thank you.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 12700
specs on that amp??
Username: Ricez
Post Number: 26
spec: http://www.sonicelectronix.com/item_6549_Boss+GT1500D.html
Username: Ricez
Post Number: 27
From what I read in the amp manual, it supports 1 ohm but does not state the rated and peak powers.
Username: Cplaya280
Quakertown, PA USA
Post Number: 659
i have a kicker L7 15" its 4ohms but i wired it parallel to make it 2ohms stable because i have the kicker zx1000.1 amp.
Username: Ricez
Post Number: 28
My Kicker L5 15" is 2 ohms, so in parallel it is 1 ohm and series is 4ohm.
Username: Cplaya280
Quakertown, PA USA
Post Number: 660
it would have been better if you got the 4ohm version because the amp your going to power it is not 1ohm stable so you wont get alot of power out of it from the sub.
Username: Ricez
Post Number: 29
Cool. That isn't going to give me RMS. What amp is recommended for this subwoofer?
Username: Cplaya280
Quakertown, PA USA
Post Number: 661
id probably go wit the kicker zx1000.1, thats the one i have but with the 15" L7. and it sounds great.
Username: Ricez
Post Number: 30
Thats too expensive for my taste. Any recommendations between $100 to $200. I thought I saw a Hi-fonics one the other day.
Username: Dakangofkrunk16
Post Number: 879
"Kicker 15 L5 serial or parallel?"
Series You mean... LOL am i the only one that noticed that
Hi-Fonics are over rated
Username: Extrmndor3
Post Number: 6633
so what????at least they are good.... they are not extremely overated they are nice for the money.... jsut because they are lil overated doesnt mean they are not good... they have nice power at a nice price and with nice sound quality nice efficiency and strong well built amps
Post Number: 880
Neva said they weren't just said Over Rated.. Didn't tell him not to get it or ne thing so yea
Username: Ricez
Post Number: 31
Yes, I meant series. So what do you recommend?
