Where to buy amp wiring kits
Username: Fearthisskyy
Dallas, Texas United states
Post Number: 388
easy question, best place to buy 1/0 gauge amp wiring kits?
Username: Skibum12189
Cleveland
Post Number: 1363
ebay, search kicker pkd1, its a great 1/0 kit, comes with like 21 feet of 1/0, all the distros, everythnig minus rca's for like 80 bucks, which is a decent deal, the hyperflex kicker wire is reallly easy to work with
Post Number: 389
http://cgi.ebay.com/New-KICKER-PKD1-Amp-Kit-1-0-Gauge-AWG-Dual-Wire-05PKD1_W0QQi temZ200140328098QQihZ010QQcategoryZ79815QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
that one?
Post Number: 390
do i have to buy the fuses for the distribution blocks?
Username: Th3pwn3r
Post Number:...
Post Number: 4197
It comes with a 300 amp ANL fuse from what I just read.
Post Number: 391
but that's the fuse for the wire close to the battery. do you need two fuses for the wires closer towards to where the distro. blocks are at?
