Woofer Conversion Chart (Cone Area) ...
Username: Rovin
4 10 Pioneer...
Post Number: 11938
For those who always wondering\asking if 2 of this size speaker will have more suface area than 2 of that & feeling lazy to work it out - check this out :
http://www.iasca.com/classes/chart.php
man they even did the math for 64 woofers too .....
Username: Skibum12189
Cleveland
Post Number: 1339
thats awesome but i honestly hope people can figure that sh!t out by themselves...
Pi R ^2
A pic is worth 1000 posts!!
Post Number: 9156
Added to fav's. Thanks Rovin.
Cleveland
Post Number: 1345
haha who has 64 18" subs
Username: Phil_salisbury
Post Number: 291
That chart maybe good if your trying to guessimate surface area for subwoofers, but, if IASCA is using that chart as a " standard " for competition classification, then it's a load of crap because not all subwoofers of the same size have exactly the same cone surface area.
Username: M0nkeyman692
Post Number: 284
but it does help for example if you have 2 12in ssd's and one 18in ssd and you want to know which has more sa.. since the cones are built the same just at different scales
Post Number: 292
" but it does help for example if you have 2 12in ssd's and one 18in ssd and you want to know which has more sa.. since the cones are built the same just at different scales "
Well, that would only be true if the geometry of the cones is all the same as to to depth of the cone and angle of the cone and since manufacturer's don't state this geometry as part of the t/s parameters, then you cannot be certain as to what that chart implies.
Besides, most manufacturer's list the cone area of the subs in the t/s parameters as (Sd).
