Subs???
Username: Pbplayer05
Carroll, Iowa
Post Number: 74
my friend just got a diamond audio d3 400.1 and he needs some advice for either one sub or 2 that would match the amp and if im right the amp is probably a little underreated so if anyone has any suggestions hit me up thaks
Username: 420alldaylong
Post Number: 2306
Diamond Audio D3 12"
Carroll, Iowa
Post Number: 76
anyone else have any ideas
Username: Fearthisskyy
Dallas, Texas United states
Post Number: 324
only researched subs that take 700wrms+
but is he looking for SQ or SPL?
what is the budget?
Post Number: 2309
Kicker CVR 12"
AudioQue SD2-SD2.5 12"
Rd classic/studio 10"12" I think Kevin got one for cheap give him a email lowhz01@yahoo.com
Mach5 audio MAW 10"12"
Alpine type r 10"12"
Cerwin Vega V max 10"12"
Elcipse SW6200 10"12"
JBL GTO 10"12"
OZ Audio OZ V12.3 10"12"
Phoenix Gold ZR-10"12" or RDS 10"12"
Polk Audio MOMO 10"12"
Carroll, Iowa
Post Number: 77
would that amp power two of any of those though our would he just be running one im not sure if the amp would do more or less than wat it says
Carroll, Iowa
Post Number: 78
probably 200 or 250 for pair or single
Carroll, Iowa
Post Number: 79
anyothers
Post Number: 2314
One from the list above,just make sure you match the ohm load from the sub to the amp.
Carroll, Iowa
Post Number: 82
would he beable to run two subs or just one does anyone know if diamond is under rated
